Report Format
  • Report Format
    Can we get an AS9102 report format into PC-DMIS? They use this format industry wide, but it is not included with PC-DMIS. Why not? I don't want a work around. I would like to select the AS9102 format and populate it with my dimensions.
    Build one!
      One may type "See CMM Report" into the Actual Dimensions box. Quite neat and easy, and does not create a form a mile long.
        Do you have QC-Calc?
        You could put your AS9102 report on the CMM, put tags into the form, and QC-Calc will automajically transfer ther results.
          +1 That's what I always did while I was working in aerospace.
            Especially on all FAIRs...common practice conforming to all applicable Aerospace controls.... and for 'Belts & Braces' I always provided the relevant serial number of the Cmm.
            Poleaxe
            Beware the environment you live in for it will shape you
            Be careful the friends you choose for you will become like them.
              A man (or woman) may also include an item# relating to a "balloon print", and the AS9102 form within the CMM report. So many ways...........
                One may get fired if trying to pull that around here. Would not make sense to build this report format into the PC-DMIS? At least form 3.
                  AS9102 does not require any specific format. It requires specific information to be included, but leaves up to the company to make their own form, if they so choose.
                  Referencing a CMM report is not atypical and is accepted by most of the larger aerospace companies, even DoD.
                    +1
                      May I add I have employed this method for years, to the satisfaction of every major defense and aerospace company in the U.S.
                        +1
                        Poleaxe
                        • jcowan
                          PCDMIS AS9102 FAIR Populating Software
                          by jcowan
                          Does anyone have the AS9102 First Article Inspection Report Software that Hexagon sells , that populates your PCDMIS report into a FAIR Format and was...
                          05-08-2008, 06:31 PM
                        • BANDY
                          Inspection Report
                          by BANDY
                          I use an AS9102 form 3 for inspection report which I was able to open in pc-dimas. Now how do you get the measurments to print into this format. Example...
                          09-06-2006, 03:28 PM
                        • j.gonzalez
                          As9102
                          by j.gonzalez
                          trying to see if anyone's got code to convert an inspection report to an AS9102 form fo a f/a
                          07-09-2009, 12:10 PM
                        • frankv
                          Excel Report AS9102 Format
                          by frankv
                          I recently downloaded a script file from the Wilcox website that populates an Excel inspection report with the PC-DMIS results. Does anyone have a script...
                          08-02-2006, 02:19 PM
                        • BANDY
                          As9102 Form 3
                          by BANDY
                          Does anyone use this form for inspection report? Is there a way to make PC-DMIS CAD 4.0 print the nominals and actuals with the tolerance in this document?...
                          09-08-2006, 07:16 PM
