I have always used "Iterative" alignments to marry part model with program and have been very successful. What are the rules for using "Program Mode"? And why would one use "program mode" as oppose to "iterative" alignments?
Program Mode vs Iterative Alignment
Prismatic Parts
If your parts have square faces and well defined datums, then Program Mode alignments are simple enough.
If your parts are contoured surfaces with no flat sides nor square corners, then iterative alignment is the way to go.
You can also use iterative alignments in prismatic parts (1st paragraph) but it is your choice.
I concurr with what Don had said and in addition, there is another reason for choosing to go the "program mode" route (also sometimes referred to as basic 3-2-1 alignment mode).
If you have no model to work with or the model is corrupt or otherwise unusable, and if the part as Don stated, has "well define datums", then a program mode alignment is the way to go. It is also in some cases more preferred in that the program mode doesn't take nearly as long to establish it's alignment.Thomas Stewart
Quality Technician/CMM Programmer
2010 MR1
Mitutoyo BN715
CMMC-3 Controller
Problem??
I'm not sure I understand the problem then. What you describe is how the iterative alignment should work now. The level points set the datum for one axis, the rotation points another axis, and the origin point is only used for the final axis. Some of this depends on which types of features you use though. . .
by CavemanI'm trying to align a part without a fixture and having no success. Refer to the picture below, which also shows the datums. The part is not reinforced...
02-05-2015, 09:16 AM -
by bgwh3I haven't worked with iterative alignments in some time. I am manually measuring my alignment features and then creating an iterative alignment. I...
02-26-2018, 05:08 PM -
by enviroLets pretend I wanted to make a video instructing someone how to do a iterative alignment. Does anyone know where I would start and what I would do all...
06-03-2009, 11:04 AM -
when you do a iterative alignment on a part that does not use the datum's. In that iterative alignment how does that affect the measurement accuracy on...
11-13-2017, 09:27 AM -
I got this one program that uses iterative alignment and whenever i try to execute just one feature of the alignment (cylinder for datum B and/or C),...
10-03-2014, 09:16 AM -
