Angle Readout
  • Angle Readout
    I have a part 1.500 Dia. with a .365 thru hole in center. There are 4 holes .125 Dia in this part on a .794 Dia. bolt circle, 30 degrees off the X-axis. I have a notch that is parallel to the holes. I'm working in the ZPLUS workplane. My readout gives me the correct dimension to each hole, but I cannot get a Deg/Min/Sec readout that is even close to being correct. I have changed my workplane to all of the others in the list, and still nothing reads the angle correctly. Any advice, Thanks
    "I hear voices, . . . and they don't Like YOU!"
    Are they just backwards. can you construct a line from the diameters to the center and dimension them?
      What is the number it gives you?
      Did you try entering the nominal in the window when you dimension the angle?
        What about PA (polar angle)?
