I have a drawing witch (seasonally speaking) has a few Metric Threads with true position callouts to them. They also have a Maximum Material Condition modifier on them.
My question is how to you measure an M6X1.0 or M8X1.25 (internal) thread to apply your bonus tolerance to the true position. What is the nominal and the tolerance for these sort of features that should be used when one isnt specified.
With the CMM I can only measure the Minor Diameter, so I found the tap drill size for the M6 and M8 to be 5.0 and 6.8mm accordingly, but Im unsure what the tolerance would be on this sort of hole, and I guess I dont even know if Im on the right train of thought in this case.
Im sure someone out there probably does this sort of thing everyday, so I was hoping I could use a "phone a friend" on this one.
Thanks
Thanks
