How do I fix measured probe diameter error exceeds the limit?
Calibrating new built stylus.
Check probe stylus for damage or dirt. Check calibration sphere for damage or dirt. Make sure that the calibrated size of the sphere has been enter correctly in the probe setup. Clean / replace / update as needed. Evaluate limits.
By the way form is far more important than the probe diameter. The probe is just a giant on/off switch with some dead band (slop) in it. The purpose of probe calibration is to determine the effective diameter of the probe taking into account the dead band as compared to the known size of the calibration sphere. The effective diameter is what is compensated for when a point is taken on a surface.
by jacyEdWe have been using a TP-200 with out RS-670 running 3.7 MR3. The probe has pretty much reached the end of its lifespan and we attempted to replace it...
10-11-2006, 07:18 AM -
by Tito81I'm trying to calibrate the master probe but I got error the diameter exceed the limits and when I checked the results my stddiv is .0001 and my warning...
08-06-2019, 12:34 PM -
by BANDY
Ok I got my new PC-DMIS setup, so I am ready to try it out. Got stuck at probe calibration. I am using a 2.5mm x 32mm probe,...-
07-19-2006, 05:46 PM -
When I qualify the probe tip it measures .0015 smaller. It doesn't matter what the probe diameter is 1,2 or 3 mm it will say probe exceeds deviation....
07-26-2011, 12:05 PM -
by williamI tried to search for this issue but couldn't find it addressed already (although I'm sure it probably has been) I'm newer to programming and haven't...
12-10-2014, 11:38 AM -
