In 4.1 - does anyone know how to turn this off. It's appears to be causing a prolem with a staged program using an equate alignment command that runs fine in 3.7 mr3. I don't see anything in the setup box. A registry setting perhaps?
Any order execution
Any Order Execute Tolerance
You need to set the ANyOrderExecuteTolerance to 0 (zero)
I believe this is under F5 (Setup) in that long list of settings in the middle of the dialog. YOu should also be able to find it in the Settings Editor if you prefer.
0 disable this function, non-zero acts as the tolerance and enables the function.
How Stuff Works
Any Order Execute is a feature put in to accomodate measurements with "arm" machines, or any manual machine for that matter. It means that you can run the program and measure any feature at any time, it finds the feature in the program based on the results of the measurement, within a certain tolerance (AnyOrderExecuteTolerance). It uses colors in the edit window to identify which have been measured and which are yet to be measured. These same colors have created complaints for uses of standard (DCC) CMMs, but now in v4.2 even the colors can be turned off. Currently, turning off AOE does not turn off the colors.
Originally posted by Don RuggieriAny Order Execute is a feature put in to accomodate measurements with "arm" machines, or any manual machine for that matter. It means that you can run the program and measure any feature at any time, it finds the feature in the program based on the results of the measurement, within a certain tolerance (AnyOrderExecuteTolerance). It uses colors in the edit window to identify which have been measured and which are yet to be measured. These same colors have created complaints for uses of standard (DCC) CMMs, but now in v4.2 even the colors can be turned off. Currently, turning off AOE does not turn off the colors.sigpic
I have to believe in DCC the program will stay linear. This is the first I've heard of this, I bet it would speed up manual a lot. I am already thinking of problems though. Who knows maybe they are handled well. I'd love to hear from someone who uses it.
Originally posted by JamesMannesThanks Don for answering my question. Don't mind the rest of my drivel re: module crap, I appreciate you taking the time(really I do, where do I send the beer?)
SSSSCCCHHHHHHLLLLLLLLLLLLUUUUUUUUUUUPPPPP!!!
Welcome to the club!sigpic"Hated by Many, Loved by Few" _ A.B. - Stone brewery
Drivel??
Jim, that's ok, I had my drivel filter on
Actually, this is a built-in (non-modular) component integral to PC-DMIS. I just forgot to answer that part.
AnyOrderExecute does not change the DCC execute order.
If you measure a feature that is not in the program, this is the same as if you measure a feature which is too far from where it should be (as deinfed by the tolerance) you get an error message. It basically says that it could not find the feature, and then offers some options on how tp proceed.
I agree that the default AnyOrderExecuteTolerance should be '0' (to disable it) but I am not sure if that's currently the case.
by WolfManI had to restore the machine, long story short I want to make sure I have proper setting under f-5. Could some one pleeeease provide me with options that...
11-11-2013, 02:52 PM -
by R2ah1ze1lWe have an offline seat here that isn't used much for programing until recently. They can access the main portions of pc-dmis to create a program but...
01-23-2014, 10:53 AM -
by GUS THE BUSWhen changing the tolerance a box appears and asks you to carry tolerance forward, or you can put a check in a box not to ask you again. I put a check...
04-06-2010, 12:37 PM -
by dennisgilpinCan anybody tell me where to turn on Autosave in the settings editor? PC-DMIS 2011MR1
Thanks-
07-26-2012, 07:24 PM -
by vvss22Hello!
1. Sometimes I see that inside my report settings are changed, after checking I see check marks inside checkboxes where I didn't put them....-
09-27-2021, 04:40 AM -
