I have a plane created from 9 edge points taken around the perimeter of a round opening. Originally I reported profile to the datums (form and location and got a result of about 1.5mm. The customer wanted a profile of 1mm form only, so I added a profile report of the plane, 1mm tol, form only. It gave me the same result. Then I decided to try creating a feature set from the points and report form only profile that way. Same result. ??? So I created an alignment, leveled to the plane itself and then reported form only profile. Finally I got a result of .4 mm, what I expected. My question is, doesn't PC-DMIS best fit a plane or a scan to itself to report form only profile and isn't that essentially the same as what I did by leveling to the feature itself?
form and location vs. form only
by oriental_sunTypically i have always dealt with profile as a form/location callout. If it is a form only profile would it say on the print or in notes? Or is there...
11-22-2010, 09:42 AM -
by atommonkeyzPart is tube with cone on end of it . Has profile tolerance of 0.002 on the inner and outer sides of the cone. Part is aligned to I.D. of tube. What is...
10-14-2015, 02:28 PM -
by DaSaloLegacy Dimensions:
What is the difference between a Form Only - No Fit profile dimension and a Form and Location profile dimension? Since the former...-
02-27-2014, 02:25 PM -
by Mike RuffI have a part similar-looking to a camshaft with 17X profile of a surface (form only) called out all the way down the length of it. It seems that the...
03-14-2011, 05:06 PM -
by WolfManI almost hijacked another thread, sorry for that.
Her is my question: profile .002 (no datums), disregard the -A-
I have...-
05-13-2015, 10:36 AM -
