Hello All,
I would like to starting using a ceramic semi-spherical probe SEMI-SPHERICAL.jpgto write some programs. It will mainly be used to measure ODs and IDs without having to keep changing probe tips like what you have to do when using a star probe. When trying to build the probe under the probe utilities window, I don’t see any description listed that would come close to describing the probe. Got any ideas? Any input would be greatly appreciated. Here is where I am currently at with building the probe setup in the probe utilities window:
TESA -M
Joint:b angle
Joint:a angle
Connect:TESA_TMA_300
Connect:TesastarMP_Body
Connect:TesastarMP_module_EF
Empty Connection #1
Thanks in advance....
TESA -M
Joint:b angle
Joint:a angle
Empty Connection #1
