Skipping Dimensions in a Report Window; V4.1
  • Skipping Dimensions in a Report Window; V4.1
    I am trying to skip around some of my dimensions in the report window, if certain conditions are met. I can of course turn off all dimensions that are INTOL, but sometimes, if a certain condition is met, I want to output more than just that 1 dimension.
    A constructed cylinder comes to mind. If the Cylindricity of the cylinder gets beyond a certain number, I'd like to see the circularity for the individual circles. So as long as Cylindricity for that feature is below X, I do not want to see the individual circles. When it is above X (and not necessarily OUTTOL yet) I want to start see the individual circles pop up. This allows me to feed process related information back to the machine operator (like tool wear) BEFORE I make scrap.
    I tried the following, without any success. That may be obvious.
                ASSIGN/V8 = 1
                IF_GOTO/V8==1,GOTO = L1
    DIM LOC103= LOCATION OF CIRCLE SIM DATUM -F-  UNITS=IN ,$
    GRAPH=OFF  TEXT=OFF  MULT=10.00  OUTPUT=BOTH
    AX    NOMINAL       +TOL       -TOL       MEAS        DEV     OUTTOL        MAX        MIN
    X     1.49980    0.00100    0.00100    1.49981    0.00001    0.00000    1.62469    1.37486 ----#----
    Y     0.00000    0.00100    0.00100   -0.00007   -0.00007    0.00000    0.12503   -0.12511 ----#----
    D     0.25012    0.00010    0.00010    0.25030    0.00018    0.00008    0.25043    0.25012 -------->
    RN    0.00000    0.00100    0.00000    0.00016    0.00016    0.00000    0.00007   -0.00009 -#-------
    END OF DIMENSION LOC103
    L1         =LABEL/
    Anybody else an idea how I can skip dimensions in a report?
    Thanks, Jan.
    That should work. I am running a program right now that I skip over certain items. What I think you need to do is view the report in "last execution" mode. Then you will see what you just ran and not every marked item(full report shows you everything marked nothing unmarked).
      Thanks James! Problem solved. It DOES skip around it, IF I re-execute.
      Perfect, just what I needed.
      Jan.
        Like James said I think last execution should do it. If you must you could probably could script it as a last resort.
        Craig
        Too slow
