moving points off the cad model
  • moving points off the cad model
    Hi all, I am trying to do some programming from the cad model. I don't get to do this much. I am using the auto circle feature and taking 8 points around the circle (start 15° - end 345°) I need to move my 2nd and 3rd points away from a slot. I can display the hits, move the points (I can see the numbers change) click ok. Display hits again the moves are still there, but when I run the circle it doesn't measure in the new locations. It still measures the 1st locations off the 45° angles. Do I need to do something after clicking OK and before I click measure? I don't know if this matters, but I measure the hole first, then F9 the circle and moved the points? Is this part correct.
    Thanks
    3.5 mr2 cad++
    PCDmis 3.5mr2 CAD++
    Try taking less points and see if that helps.
      Try again using a new auto-circle.
        Make your adustments before running the auto-circle.
          Ok James, How do I do this. The display hits button is blanked out. I was thinking about something like that. I tried find noms, master it always goes back the original spots.
          PCDmis 3.5mr2 CAD++
            Mr. Bw_Bob, I could do this and it would work. I have a little time today so I am trying to learn some things about Cad programming. I don't get to do it and this was a post some time ago, just can't find it. I was wondering if it was something to do w/ 3.5mr2.
            PCDmis 3.5mr2 CAD++
              I use 3.5mr2 and have had no problem editings things using model. Wonder if its the model itself ???
                Do you see the hits on the screen? If so, there are green ones, 1 orange, and 1 red. Grab either the orange(end angle) or the red(start angle) and move the arrows until you aren't hitting the slot.
                  I am playing w/ the B&S demoblock model. Solid and wire. Could this be it.
                  I have to run a couple of parts. I will try this after lunch and let you know.
                  Thanks for your help.
                  PCDmis 3.5mr2 CAD++
                    I dought its the model, but who knows. You have surface & curve mode, have you tried toggling between those.
