Dilemma with datums
  • Dilemma with datums
    What I have run into while looking into correlation issues with a customer is datum feature measurement. The parts were programmed with CAD (and using measured features) and I am not sure why or how (noms NOT from CAD this was done as I always use auto features or consrtucted feaures from individual points. I am seeing at least .001" difference in the measured results between their original program and their program with the datums feature's nomials reset to zero. This makes a huge difference between reporting the part as good or bad.
    I have tried to duplicate what they have done off the CAD model and cannot get the same numbers they have. What I am seeing in their program is nominals and vectors being different from the CAD when I pull feature off the CAD.
    Something we ran into a year and a half ago with a similar program from them was that with the noms being off is seemed to skew the alignment. Does the DEMON look at the noms of datum feature(s) and use them in the math to say where and how that feature should be used in the DRF??
    Their program code, the "Z's" and vectors are not at nom. I don't know how the targets were changed becuase when I pull feature point off that model the zero reads zero and the vectors are square.
    DATUM-A-   =FEAT/PLANE,RECT,TRIANGLE
                THEO/0.0008,0.9069,0,-0.000024,0.0001118,1
                ACTL/0.0008,0.9069,0,-0.000024,0.0001118,1
                MEAS/PLANE,8
                HIT/BASIC,NORMAL,-1.3976,0.6606,-0.0002,-0.000024,0.0001118,1,-1.3976,0.6606,-0.0002,USE THEO = YES
                HIT/BASIC,NORMAL,-1.287,1.1577,-0.0002,-0.000024,0.0001118,1,-1.287,1.1577,-0.0002,USE THEO = YES
                HIT/BASIC,NORMAL,-0.5636,1.1438,0.0002,-0.000024,0.0001118,1,-0.5636,1.1438,0.0002,USE THEO = YES
                HIT/BASIC,NORMAL,-0.5747,0.5704,0.0003,-0.000024,0.0001118,1,-0.5747,0.5704,0.0003,USE THEO = YES
                HIT/BASIC,NORMAL,0.5562,0.5953,-0.0001,-0.000024,0.0001118,1,0.5562,0.5953,-0.0001,USE THEO = YES
                HIT/BASIC,NORMAL,0.5685,1.2403,0,-0.000024,0.0001118,1,0.5685,1.2403,0,USE THEO = YES
                HIT/BASIC,NORMAL,1.309,1.1972,-0.0001,-0.000024,0.0001118,1,1.309,1.1972,-0.0001,USE THEO = YES
                HIT/BASIC,NORMAL,1.395,0.6897,0.0001,-0.000024,0.0001118,1,1.395,0.6897,0.0001,USE THEO = YES
                ENDMEAS/
                MOVE/POINT,NORMAL,1.231,0.8999,1.235
    DATUM-B-   =FEAT/PLANE,RECT,TRIANGLE
                THEO/0.0211,0.0015,0.8361,0.0000208,0.9999969,-0.0024716
                ACTL/0.0211,0.0015,0.8361,0.0000208,0.9999969,-0.0024716
                MEAS/PLANE,8
                HIT/BASIC,NORMAL,1.2345,0.0019,0.983,0.0000208,0.9999969,-0.0024716,1.2345,0.0019,0.983,USE THEO = YES
                HIT/BASIC,NORMAL,0.851,0.0018,0.9831,0.0000208,0.9999969,-0.0024716,0.851,0.0018,0.9831,USE THEO = YES
                HIT/BASIC,NORMAL,-0.7368,0.0018,0.9833,0.0000208,0.9999969,-0.0024716,-0.7368,0.0018,0.9833,USE THEO = YES
                HIT/BASIC,NORMAL,-1.1041,0.0019,0.9833,0.0000208,0.9999969,-0.0024716,-1.1041,0.0019,0.9833,USE THEO = YES
                HIT/BASIC,NORMAL,-1.2557,0.0013,0.7171,0.0000208,0.9999969,-0.0024716,-1.2557,0.0013,0.7171,USE THEO = YES
                HIT/BASIC,NORMAL,-0.7156,0.0011,0.717,0.0000208,0.9999969,-0.0024716,-0.7156,0.0011,0.717,USE THEO = YES
                HIT/BASIC,NORMAL,0.65,0.001,0.6611,0.0000208,0.9999969,-0.0024716,0.65,0.001,0.6611,USE THEO = YES
                HIT/BASIC,NORMAL,1.2458,0.0011,0.6609,0.0000208,0.9999969,-0.0024716,1.2458,0.0011,0.6609,USE THEO = YES
                ENDMEAS/
                MOVE/POINT,NORMAL,0.9825,0.7344,0.6613
                MOVE/POINT,NORMAL,0.0095,0.8674,0.1668
    DATUM-C_L  =FEAT/PLANE,RECT,TRIANGLE
                THEO/-0.4343,0.9768,-0.11,0.9999977,0.0007264,0.0020255
                ACTL/-0.4343,0.9768,-0.11,0.9999977,0.0007264,0.0020255
                MEAS/PLANE,4
                HIT/BASIC,NORMAL,-0.4347,1.2889,-0.0154,0.9999977,0.0007264,0.0020255,-0.4347,1.2889,-0.0154,USE THEO = YES
                HIT/BASIC,NORMAL,-0.4344,0.7185,-0.0156,0.9999977,0.0007264,0.0020255,-0.4344,0.7185,-0.0156,USE THEO = YES
                HIT/BASIC,NORMAL,-0.4339,0.719,-0.2046,0.9999977,0.0007264,0.0020255,-0.4339,0.719,-0.2046,USE THEO = YES
                HIT/BASIC,NORMAL,-0.4343,1.1807,-0.2043,0.9999977,0.0007264,0.0020255,-0.4343,1.1807,-0.2043,USE THEO = YES
                ENDMEAS/
                MOVE/POINT,NORMAL,0.0137,1.0226,-0.2045
                MOVE/POINT,NORMAL,0.0137,1.0225,-0.2045
    DATUM-C_R  =FEAT/PLANE,RECT,TRIANGLE
                THEO/0.4341,0.951,-0.1154,-0.9999981,-0.0008617,0.0017278
                ACTL/0.4341,0.951,-0.1154,-0.9999981,-0.0008617,0.0017278
                MEAS/PLANE,4
                HIT/BASIC,NORMAL,0.4338,1.1547,-0.2044,-0.9999981,-0.0008617,0.0017278,0.4338,1.1547,-0.2044,USE THEO = YES
                HIT/BASIC,NORMAL,0.4342,0.7388,-0.2046,-0.9999981,-0.0008617,0.0017278,0.4342,0.7388,-0.2046,USE THEO = YES
                HIT/BASIC,NORMAL,0.4345,0.7383,-0.0263,-0.9999981,-0.0008617,0.0017278,0.4345,0.7383,-0.0263,USE THEO = YES
                HIT/BASIC,NORMAL,0.4341,1.1722,-0.0261,-0.9999981,-0.0008617,0.0017278,0.4341,1.1722,-0.0261,USE THEO = YES
                ENDMEAS/
                MOVE/POINT,NORMAL,0.1884,1.1694,-0.0261
                MOVE/POINT,NORMAL,-0.1962,-0.0101,1.353
    DATUM-C_POINT=FEAT/POINT,RECT
                THEO/0,0.9179,0.0515,-0.0000303,0.0000596,1
                ACTL/-0.0001,0.9639,-0.1127,-0.0002018,0.0007842,0.9999997
                CONSTR/POINT,MID,DATUM-C_L,DATUM-C_R
    DATUM-B_LINE=FEAT/LINE,RECT,UNBND
                THEO/-0.0036,-0.0007,0.0006,1,-0.000075,0.0000066
                ACTL/0.0109,-0.0006,0.0001,1,-0.0000207,0.000024
                CONSTR/LINE,INTOF,DATUM-B-,DATUM-A-
    AL-AUTO    =ALIGNMENT/START,RECALL:AL-MAN, LIST= YES
                ALIGNMENT/LEVEL,ZPLUS,DATUM-A-
                ALIGNMENT/ROTATE,XPLUS,TO,DATUM-B_LINE,ABOUT,ZPLUS
                ALIGNMENT/TRANS,XAXIS,DATUM-C_POINT
                ALIGNMENT/TRANS,YAXIS,DATUM-B_LINE
                ALIGNMENT/TRANS,ZAXIS,DATUM-A-
                ALIGNMENT/END
    This is their code after tweaking to CAD noms making the "Z's" all read zero and setting the vectors to CAD zero.
    DATUM-A-   =FEAT/PLANE,RECT,OUTLINE
                THEO/0.0008,0.9076,0,0,0,1
                ACTL/0.0008,0.9076,0,0,0,1
                MEAS/PLANE,8
                HIT/BASIC,NORMAL,-1.3975,0.6612,0,0,0,1,-1.3975,0.6612,0,USE THEO = YES
                HIT/BASIC,NORMAL,-1.287,1.1583,0,0,0,1,-1.287,1.1583,0,USE THEO = YES
                HIT/BASIC,NORMAL,-0.5636,1.1445,0,0,0,1,-0.5636,1.1445,0,USE THEO = YES
                HIT/BASIC,NORMAL,-0.5746,0.5711,0,0,0,1,-0.5746,0.5711,0,USE THEO = YES
                HIT/BASIC,NORMAL,0.5562,0.596,0,0,0,1,0.5562,0.596,0,USE THEO = YES
                HIT/BASIC,NORMAL,0.5686,1.241,0,0,0,1,0.5686,1.241,0,USE THEO = YES
                HIT/BASIC,NORMAL,1.309,1.198,0,0,0,1,1.309,1.198,0,USE THEO = YES
                HIT/BASIC,NORMAL,1.3951,0.6905,0,0,0,1,1.3951,0.6905,0,USE THEO = YES
                ENDMEAS/
                MOVE/POINT,NORMAL,1.231,0.8987,1.235
    DATUM-B-   =FEAT/PLANE,RECT,OUTLINE
                THEO/0.0212,0,0.8355,0,1,0
                ACTL/0.0212,0,0.8355,0,1,0
                MEAS/PLANE,8
                HIT/BASIC,NORMAL,1.2346,0,0.9824,0,1,0,1.2346,0,0.9824,USE THEO = YES
                HIT/BASIC,NORMAL,0.8511,0,0.9825,0,1,0,0.8511,0,0.9825,USE THEO = YES
                HIT/BASIC,NORMAL,-0.7367,0,0.9828,0,1,0,-0.7367,0,0.9828,USE THEO = YES
                HIT/BASIC,NORMAL,-1.104,0,0.9827,0,1,0,-1.104,0,0.9827,USE THEO = YES
                HIT/BASIC,NORMAL,-1.2557,0,0.7165,0,1,0,-1.2557,0,0.7165,USE THEO = YES
                HIT/BASIC,NORMAL,-0.7155,0,0.7164,0,1,0,-0.7155,0,0.7164,USE THEO = YES
                HIT/BASIC,NORMAL,0.6501,0,0.6605,0,1,0,0.6501,0,0.6605,USE THEO = YES
                HIT/BASIC,NORMAL,1.2459,0,0.6603,0,1,0,1.2459,0,0.6603,USE THEO = YES
                ENDMEAS/
                MOVE/POINT,NORMAL,0.9825,0.7332,0.6613
                MOVE/POINT,NORMAL,0.0095,0.8662,0.1668
    DATUM-C_L  =FEAT/PLANE,RECT,OUTLINE
                THEO/-0.4345,0.9775,-0.11,1,0,0
                ACTL/-0.4345,0.9775,-0.11,1,0,0
                MEAS/PLANE,4
                HIT/BASIC,NORMAL,-0.4345,1.2896,-0.0152,1,0,0,-0.4345,1.2896,-0.0152,USE THEO = YES
                HIT/BASIC,NORMAL,-0.4345,0.7192,-0.0158,1,0,0,-0.4345,0.7192,-0.0158,USE THEO = YES
                HIT/BASIC,NORMAL,-0.4345,0.7198,-0.2048,1,0,0,-0.4345,0.7198,-0.2048,USE THEO = YES
                HIT/BASIC,NORMAL,-0.4345,1.1815,-0.2042,1,0,0,-0.4345,1.1815,-0.2042,USE THEO = YES
                ENDMEAS/
                MOVE/POINT,NORMAL,0.0137,1.0213,-0.2045
    DATUM-C_R  =FEAT/PLANE,RECT,OUTLINE
                THEO/0.4345,0.9518,-0.1154,-1,0,0
                ACTL/0.4345,0.9518,-0.1154,-1,0,0
                MEAS/PLANE,4
                HIT/BASIC,NORMAL,0.4345,1.1556,-0.2043,-1,0,0,0.4345,1.1556,-0.2043,USE THEO = YES
                HIT/BASIC,NORMAL,0.4345,0.7396,-0.2048,-1,0,0,0.4345,0.7396,-0.2048,USE THEO = YES
                HIT/BASIC,NORMAL,0.4345,0.739,-0.0264,-1,0,0,0.4345,0.739,-0.0264,USE THEO = YES
                HIT/BASIC,NORMAL,0.4345,1.173,-0.026,-1,0,0,0.4345,1.173,-0.026,USE THEO = YES
                ENDMEAS/
                MOVE/POINT,NORMAL,0.1884,1.1681,-0.0261
                MOVE/POINT,NORMAL,-0.1962,-0.0113,1.353
                THEO/0,0.9647,-0.1127,0,0,1
                ACTL/0,0.9647,-0.1127,0.0000067,-0.0005882,0.9999998
                THEO/0,0,0,1,0,0
                ACTL/0.011,0,0,1,0,0
                ALIGNMENT/END
    Contura Calypso 5.4
    Your AL-AUTO commands are different; different alignment recall, different rotate, different yaxis.
      Yes, I forgot to change that back before the paste, I had played with the alignments trying to get different results. You can ignore that, my apologies
      Contura Calypso 5.4
        Did you re-execute the alignment after tweaking the vectors?
          I created a second program with the original alignment then a third program with the tweaked alignment.
          Contura Calypso 5.4
            I use to tell my customers "If you lie to PC-DMIS (i.e. don't enter correct THEOs), then PC-DMIS will happily lie back to you in the results!" ...
              That is what I am thinking. Without knowing how the calculations are used against the model, I would assume that the software compares the actuals against the nominals and says "this is how I am supposed to oriented and located" and levels/origins accordingly.
              Contura Calypso 5.4
                One of the 10,000 things commonly forgotten from the 101 class is:
                When using Measured Features, always go back and correct all nominal XYZ and IJK values for everything to print/CAD nominal or your DRFs will be off.
                We recently changed our course structure to allow the students to start using CAD right away, because of the high rate of students whose retention rate hit the full mark after they learned to make features with the jogbox but before CAD was introduced. If I had a nickel for every sloppy measured-feature alignment I've seen...
                Good luck with the battle, Dwade.
