Recently we have been having problems with disappearing probe files that have at one time been used and established. We open a prior running program to have a warning that the probe has not be defined, where it was used with no issues prior to this in this program. Then when you F9 the probe file name in the edit window, the probe is not described/defined, all of that probe's construction is gone. Does anyone have any ideas how to fix this?
One more thing in the probe folder, that probe file is missing now, hence why there is no construction shown, but there is the remaining results file, from it's prior cal. My suggestion was to go to MR3, but then I was countered with the fact that this only has just started happening, it's a new problem. so it's not necessarily a version issue.
