Hi all.
version 3.5mr2
I have only written 3 programs with models, so I have little experience with programming with models.
I write programs on airfoil segments. Our procedure we write an alignement program, we do not use iterative alignments, and save the alignment as an exteranl alignment. We do not import the model in at this time. Then we write individual external programs for inner shroud, outer shroud, gas path, DO, slashface. These programs start off with external alignment recall and then I import the model.
I have the model set up to the same orientation at the external alignment.
I wrote a program for the BORO version of this segement and everything was fine.
Now I want to create another program for the inner shroud. I go through the same procedure as the BORO program, BUT now when I import the same model the trihedron is not in the correct location. (See attachment). The external alignment hasn't changed. I can enter the blueprint location for vector point and it takes the point correctly, the model hasn't changed because I use the same model as before, but if I click on the model to take a point it is shifted in the +X.
Any help is greatly appreciated.
Teresa
version 3.5mr2
Teresa
