I've search the threads on these issues and I do believe I know the problem but I just want to see if I can get some confirmation on what I believe. I am getting a datum error on almost any B0 angle. I have switch A angle all around and also use all other B angles no problems it seems. Tried a shutdown, reset probe head controller, check the E-stop, look to see if there are any damaged wires that I could see ethier on the probe head controller or the probe itself. It locks like normal then within about 2 too 3 seconds it tries to lock again and that is when the datum error occurs. Could I assume that this is a mechanical issue being that I don't get the error in other angles? Also I do alot of angle changes in my programs is there more robust probeheads out there then the ph10M? This is my second one. I'll admit my first one I learned on and it did have a couple good crashes. This one though has never been crashed (or very minor ones). I believe I got it sometime 2009 (can't remember exactly).
PH10M Datum Error
Attempt this at your own risk!!!!!!!
I am NOT a repair tech, just passing along info I've gotten over the years.
On the PH9/PH9A and on at least one of the PH10 models there is a very small 'hole' in the left side of the square part of the head. If your head has this hole, then inside that hole (too deep to see) there is a set screw. Tighten it 1/4 turn to see if that fixes the problem.sigpic
Hi Adam, I don't think there's more robust than PH10... I had one during 12 years without any problem. I've now a tesa star, it works well, but only since 2 years.
For your actual problem, maybe you could try to unlock the ph10, and clean it with a cleaner for pc (little bottle of gas, I don't know how to call it in english !).
Have a good week-end, despite your problems !!!
looking for a possible solution for our PH10M unlocking and locking for its 4 attempts before having an error.I found the set scew that you 2 were talking about..what is on the other end of this..it seemed rather loose. I turned a quarter turn with no difference to my problems. We had this problem a couple weeks ago..then it seemed to have stopped..and then once again its back this week. Please let me know if you have any other ideas. Prbobe has never been hit but it is over 20 yrs old
by Rich PLong Time Forum Observer (stalker) have not posted in a a long while
Any way started new job and went from 1 machine to 4 --4 Times the...-
08-17-2012, 06:16 PM -
by TKOFaithHi all!
I'm running v3.2063 on a B&S Microval PFx machine. A week or so ago one of the air cleaner bowls ******* and my CMM has been...-
10-04-2012, 12:58 PM -
by CubicI am getting an datum error on my C.M.M ( I have an old model with a PH9A Probe head and running PC-DMIS 3.7 Revision) I can't get the program to read...
08-05-2009, 06:29 PM -
by racerx00Just thought I would ask this to see what you guys thought. Yesterday my probe just stopped working. went to change a tip in the rack and after it finished...
08-25-2009, 08:15 AM -
by Yeo Yee ShiI having some problem with DEA machine, Probe Head CW43L with SP25 setup.
when turning angle measured the master granite block, there is...-
09-19-2013, 09:58 AM -
