Ph10t
  • Ph10t
    On the probe body I guess I'm kinda screwed on this one the ball will not seat and stay seated. In the middle of a program the wrist went to change probe rotations and would not seat after that. I did a complete shut down. It will stay seated as long as I hold the button in..But can't do anything that way.
    Is there anything to look for?
    Does it have a tension adjustment screw on the side like the PH9 does? Screw it in (lefty-loosey, righty-tighty) if it has one, otherwise you are probably looking at an RBE.
      I see no screw. Guess I'll go give them the bad news
        Well, what kind of weight do you have hanging on the thing? Have you tried with less extensions and stuff?
        Also, how good are YOU at micro-manipulations? (not counting your 'buzzing-off') Do you think you could take it apart and see if there is an adjustment screw that can be adjusted and can you put it back together if you get it apart? Remember one thing, they will not accept it for RBE if it is dis-assembled. However, since it is (possibly) broken already, what can it hurt to take it apart and have a look? Just as long as you can put it back together again, all you'll be out is a little time. AND, it might just save you the cost of the RBE.
        • 56flh
          CMM errors
          by 56flh
          This is a non PC-DMIS question but maybe the experienced here have run into this situation in the past.
          I am running 3.7 mr3 on a MicroXcel...
          05-27-2008, 09:26 AM
        • 12345
          Noisy PH10MQ when it seats
          by 12345
          Have a PH10MQ that is very noisy when it seats after a probe tip change,
          it sort of gives a thud like noise.
          Any way to perhaps clean and/or...
          01-30-2009, 06:38 PM
        • W0QNX
          PH10MQ not seating all the time
          by W0QNX
          We have a problem with the PH10MQ not wanting to seat all the time (klunk). You can help it manually by rotating the head while it seats and it works....
          09-12-2008, 10:19 AM
        • btoeps74
          PH10T Won't lock into gears
          by btoeps74
          Okay to start, I may not have worded the subject line correctly, but my issue is this. I had tried cleaning off the magnetic connections for the TP20...
          11-29-2017, 04:51 PM
        • JMayle
          Probe wont take hits
          by JMayle
          Need Help Pls.We have a brown&Sharp Cmm 7.6.5 Head is a PH10M with a Tp20 tip set up.Everything was working fine then we unhooked the coords and moved...
          04-19-2010, 12:46 PM
