I just downloaded datapage v.3.33. I had version 3.32. The tech support said that it should write over top of 3.32 without any problems. I created a database for a new part and now everytime I save to datapage it gives me a error 127 message. Yet when I go check the new database all the data was dumped there correctly. ANy advice on correcting this error would be appreciated.
datapage error
DataBase
Did you use DataPage to create the database? Its more than just a folder name, make sure you have a real database.
Also, did you remove an old database? Make sure that the data in the XSTATS11.TMP is not trying to write to an older database.
-127 means that the destination database does not exist, or its trying to write to a non-database folder.
by roddawgWhat causes the following database error:
"Error: Unable to access database for write operation"
It scrolls through...-
06-08-2006, 04:46 PM -
by jaymundayAs of yesterday at the end of a program where the results update into the Datapage database I get a error. ( Database System Error -127 Database files...
Channel: DataSuite SPC
11-14-2012, 10:55 AM -
by UnderspecI'm using PCDMIS v3.7MR1 and trying to use QC Calc Real-time. It collects data from PCDMIS's xstats11.tmp file.
They tell me to configure...-
03-28-2006, 01:22 PM -
by GeisterOur 2nd shift CMM operator was doing a 30 pcs dimensional study. On the 27th part datapage displayed the following error. (Database User Error: -18 record...
04-08-2013, 01:17 PM -
by tinabeth
Hi. Thank you for your replys. I must be missing something because I still can't get pcdmis and datapage to work? So here is what I do step by step....
02-04-2009, 10:09 AM -
