Move point with the print button on the jog box.
  • Move point with the print button on the jog box.
    Help i used to be able to insert move point using the print button on the jog box now after upgrading to windows 7 this button do not work. is there a place to activate this button?
    Thanks,
    New user.
    Well, I think, depending on your controller, there is/was a place to adjust the print button to do the "move Pt", or something else...so it will be somewhere in Pc-dmis under a setting somewhere, or you may have to go to the settings editor to find it....
    Jim Jewell
      What Jim said.
      Check on:
      Edit > Preferences > Machine interference setup
      Look for the print button settings (I think is either "move Pt", delete, or none) I'm not positive...
      sigpicIt's corona time!
        Originally posted by Roberto View Post
        What Jim said.
        Check on:
        +1 it should be under the sharp32 tab in the machine interface setup
        sigpicSTANDING CORRECTED IS THE ONLY WAY I STAND
          Thank you all for the Help Adam Yes it works.
          Thanks again.
          G I
            Is there a place to make this button as a default?
            • 56flh
              Jog box "print" button
              by 56flh
              I may be overlooking something obvious, but it seems I've lost the ability to insert a move-point into a program by pressing the "print" button...
              07-19-2006, 11:38 AM
            • Farmer
              Jog Box
              by Farmer
              Hi, Im fairly new to Dmis. I have only completed the basic training, so apologies if this is a silly question. Is it possible to re-programme the jog...
              06-29-2006, 04:08 AM
            • dccfreak
              DEA Scirocco Question
              by dccfreak
              Anyone have a DEA machine and jogbox or a Scirocco? I have just gotten one and am finally getting used to the axis differences, but, now I would like...
              08-12-2006, 12:35 PM
            • gishak
              Print button help
              by gishak
              Any one knows how to change the print button to bused as a move point by default all the times?
              Thanks.
              George Ishak
              06-26-2015, 01:53 PM
            • VONDY
              Done Button Not Excepting Touch
              by VONDY
              We can not get our Done button to work on our jog box. Where is the command to turn this on? Ver 3.5mr2 sharpe 32 controller.
              01-22-2007, 06:38 AM
