Converting PC-DMIS to Geomeasure
  • Converting PC-DMIS to Geomeasure
    I'm new to PC-DMIS and I'm trying to convert the PC-DMIS file to Geomeasure. The folowing are a few lines from a sphere measurment in PC_DMIS. I need to know what Coordinates are the Theoretical XYZ points and which are the theoretical vectors. Then I can manually enter them into Geomeasure. Can anyone please help?
    SPHR1 =FEAT/SPHERE,RECT,IN
    THEO/0.00005,0.00016,0.64154,0,0,1,1.82217
    ACTL/-0.00025,-0.00034,0.64551,0,0,1,1.83299
    MEAS/SPHERE,34
    MOVE/CLEARPLANE
    HIT/BASIC,NORMAL,0.07697,0.56517,-0.06859,-0.0844656,-0.6203825,0.7797379,0
    .07702,0.56399,-0.07174,USE THEO = YES.07702,0.56399,-0.07174,USE THEO = YES
    HIT/BASIC,NORMAL,0.28501,0.48354,-0.07608,-0.3128216,-0.5306255,0.7877685,0
    .28574,0.48215,-0.0787,USE THEO = YES.28574,0.48215,-0.0787,USE THEO = YES
    -Chad T.
    X^ Y^ Z^ x, y, z, dia
      X, Y, Z, I, J, K,
      THEO/0.00005, 0.00016, 0.64154, 0, 0, 1,1.82217
      Hope this helps.
      Mike
        I think I understand the Circle definition but what about the XYZ and IJK in the actual hits?
        I need to know where to take my theoretical points and the vectors so that I can coorilate our program with another program.
          They follow the same as the theoretical.
            there are only two hits here. A sphere needs at least four.
            but anyway:
            Hit/basic,normal, o.x,o.y,o.z,o.I,o.J,o.K,i,j,k BUT YOU CAN LEAVE OFF THE LAST THREE IJK'S!
            • dwade
              Dilemma with datums
              by dwade
              What I have run into while looking into correlation issues with a customer is datum feature measurement. The parts were programmed with CAD (and using...
              06-04-2014, 02:13 PM
            • emurray
              Please take a look
              by emurray
              I am running a pre-existing program for one of our parts. The problem I am having (this time) is after I am prompted to take my manual measurments,...
              08-14-2007, 12:32 PM
            • Aguayo
              Program from Renishaw
              by Aguayo
              Please take a look this the program below,renishaw sent it to me yesterday.I
              ran it,but I did not get the results the file was emthy,renishaw said...
              05-10-2006, 08:03 AM
            • j.gonzalez
              accuarcy of a circle
              by j.gonzalez
              i got a 4 circles all measured the same tolerences are .9449/.9454 the cmm is kicking it out at .9456 i manually check the part using an air gage it's...
              06-23-2009, 11:42 AM
            • Ken379128
              Nominals changing
              by Ken379128
              Why when I run thru a program do my nominals keep changing. I go in put them to what I want and when it runs it changes it right back????...
              02-03-2007, 10:29 AM
