I need to pick up a cylinder but I'm not sure how to go about it, I'm mainly use to picking up objects with align. bushings or tooling balls, using the iterative align. Also I need to find the concentricity between two features on the cylinder. I tried using the concentricity dem. feature before & couldn't get it to output anything use able. If anyone could explain to me how to use it that would be a big help.
cylinder pick up
by ptedrumI need to pick up a cylinder but I'm not sure how to go about it, I'm mainly use to picking up objects with align. bushings or tooling balls, using the...
10-12-2006, 03:11 PM -
by JStewartGood morning!
I'm trying to create a cylinder between two existing cylinders and comng up empty. How is this done? Do I need to extract...-
11-19-2010, 10:48 AM -
by bqualityNeed help,
See attached sketch for details of setup.
As you can see from the attached sketch, we leveled to a cylinder in the...-
08-29-2008, 01:47 PM -
by cmmpro_mackI have two 0,0,1 circles and when I use them to construct a cylinder, the cylinder is 1,0,0. What is the problem.? Im using 4.3MR1.
Help...-
07-09-2009, 04:27 PM -
by jumping jacki have cylinder I need to align how does one go about same?
Thanks
Jack-
04-21-2009, 02:55 PM -
