L-probe how to
  • L-probe how to
    Hood morning fellas, I have a problem
    I want to create an L-shape probe, I only need 1 probe at A90B180, no others is that doable or do I have to create a tip at A0B0 too?
    B&S One
    PC-DMIS CAD v2014
    Romer Infinity
    You need the 5 way with all the empty holes. Add at least a 10mm ext before that part. Build your probe the way you need it, take care to make sure it is very square to your axes !
    I am not 100% sure if you need a straight down 0,0 tip or not, to be honest, I always have one....
    I bet you will because it will always add 0,0...although, your 90 180 tip will be at 0,0 head angle, so it might work fine, give it a try...I build these types of tips all the time, just never done one without a tip pointing straight down...
    Jim Jewell
      I build it, with only 1 tip A90B180, do I need to add the A90B180 angle? or how do I tell it that I want to use that tip?
      B&S One
      PC-DMIS CAD v2014
      Romer Infinity
        when you define the tip.
        after connect: exten5way
        leave connection #1,2 and 4 empty
        just add the tip to connection #3 or #5
        (I can remember which is 90,180)
        Roses are red
        Violets are glorious
        Don't try to sneak up
        On Oscar Pistorius.
        MIL-TFP-41C
        3.7mr3, 2012mr1, 2013mr1
          According my conversations with tech support you need a tip in slot 1 (straight down) the 1st time you calibrate.
          You can remove the tip and configuration after it's calibrated once.
            I have never had to add a tip to connection #1.
            As long as the software knows where the tip is you don't need a tip in connection #1.
            In any case how would you remove it without having to recalibrate?
            (The only time that may apply is when calibrating the sphere position.)
            Roses are red
            On Oscar Pistorius.
            MIL-TFP-41C
              It should be t2a90b180
              XYZ_IJK
              pc-dmis 2012 mr1, 2013mr1
              calypso 5.4 sp1
                How about this?
                The long numbers on hotspot are the cosines for the probe's angle.
                I measured the angle on paper with the probe near the table and used the comparator to get the right lengths/angles.
                ITEM:1BY10BENT90 M2
                comment 1MM probe on a 10mm probe bent 90 degrees on GREEN tesa med force module with 70mm extension
                begintip
                ribcount 10
                color 142 142 142
                cylinder 0 0 0 0 0 -2.5 3
                cone 0 0 -2.5 3 0 0 -5.85 .7
                cylinder 0 0 -5.85 0 0 -6.41 .7
                cylinder 0 0 -6.41 2.40 2.92 -6.57 .7
                color 255 0 0
                sphere 2.40 2.92 -6.57 1
                hotspot 2.40 2.92 -6.57 -.558179625 -.77317651 .057564026 1 1 ball
                endtip
                  It's doable.
                    Add tip angel A90B180, delete A0B0, calibrate A90B180. PC-Dmis knows shank vector of each tip...
                      the strange part is that it wont add the T1AB0 etc....
                      B&S One
                      PC-DMIS CAD v2014
                      Romer Infinity
                        I am using v2009mr1, it did what I described. Just add A90B180 and delete any other angles that you do not need.
                          when I added the A90B180, it rotated the Head. The other star probe works as it should, but this new L- shape one just doesnt
                          B&S One
                          PC-DMIS CAD v2014
                          Romer Infinity
                            If you are using the star probe then it shouldn’t be a problem, but if you’re using knuckle joint then you have to key in ijk xyz in probe cal edit window. It’s a bit tricky though…
                            Edit: Or you can try Caemgen’s method.
                              its ok I was able to work with my already build star probe
                              B&S One
                              PC-DMIS CAD v2014
                              Romer Infinity
