Have any of you seen this error? With the cursor at the bottom of my program I try to insert an angle change and I get this error.... "No legal insertion point below". It will then ask if I want the probe to rotate and it does but does not insert the change into the program.
Not only does it not insert the angle change, it will not allow me to take points or anything. It's weird, it's like it doesn't know that the cursor is at the bottom of the program or something. I've seen this error before but it was in the early stages of a program so I just ditched it and started over without seeing the error again so I never found out what was causing it. Any ideas? Thanks in advance.
Mike
Mike
