Dead in the water. Head rotates and so on. As soon as I start a pgm., I get a deflection error. Little red led in Renishaw head only comes on when head is rotating. That's why I think it's the TP2.
I can only tell you the problems I have had.
1) air filter on controler never changed causing it to over heat.
2) filter on air inlet to machine spurt water on circuit board causing it to go bad.
one of these caused my problem. I would shut all down and restart. good luck
Runing 3.7 ,when trying to home CMM Machine,After log on into computer, turn on the air pressure and start PC-DMIS.the pc-dmis window come up with pc-dmis...
While Cal. Tips my TESASTAR-SM ran into the top of my Cal. sphere. of course I got an Emer. stop. after I got everythin goin I can not get the head to...
