Last night, our second shift inspector was running a proven program for me. This program uses an iterative alignment. He called me last night (Shutup Craig! I know what I said yesterday!), The program wasn't finding the alignment. Just kept cycling thru. I decided to pull my backup copy of the program off of the server and just replace the one on the CMM computer. I found a .DMO file with the same name as my program on the computer. It was created monday night and modified last night. What is it? I've never seen it before.
*.DMO file
I opened this in notepad. Here are the first few lines of code. It looks like another method of outputing (is that a word?) the data, But ends at the end of the alignment.
FILNAM/'MP1017KG,,,MP1017KG.PRG'
$$ PC-DMIS for Windows Generated DMIS Output File
$$ PC-DMIS Ver: 3.2063 Release
Date=2006/10/10
Time=21:43:13
UNITS/INCH,ANGDEC
DA(STARTUP)=DATSET/MCS
WKPLAN/XYPLANWhen in doubt, post code. A second set of eyes might see something you missed.
by T Miller
Anyone know what this extension is
Got this program the other day and when I try to open it I get this error message
Tom...-
06-23-2006, 04:15 AM -
PC-DMIS 4.1 GOAL: Run a program on multiple fixtures, like a pallet function. But each run has to be a separate program run. And it needs to be the...
12-19-2012, 06:18 PM -
by AtokadProblem Solved! (Sort of…)
The problem I was facing is that there is no way to get PC DMIS to output a text file extension in lowercase....-
05-09-2017, 03:16 PM -
by jaymundayMy goal is to run a program an have my report direct itself into a file on the computer. Now I can do this through the printer option but I have no control...
06-08-2012, 09:08 AM -
by michelleHello there,
I have a program called "Inspect My Cutter". This program previously generated and output a file containing (uncompiled)...-
Channel: PC-DMIS Code Samples
10-16-2009, 05:43 AM -
