IJK Reporting?
  • IJK Reporting?
    Hi all,
    Is there a way to report the I,J,and K values of a feature in a dimension? I remember something posted about this subject, but I sure can't find it by searching this or the other PCDMIS forum.
    Gil.
    You can't dimension it without some programming, but simply click on V in the dimension box and you can report it.
    Bill
      Go to the dimension in the edit window and place curser at the end of the dimension and hit enter, X will show up hit the delete key and type V to replace the X, Tab thru prompt will come up do you want to replace simular dims and if you answer yes it will change all dims that are simular. I'm doing the same right now.
        Oh yes, that's it. Thanks.
