Anyone know how to select points place on the cad by the designer? I know I've done it before but can't seem to get it to work now. I can come close but I'd like to select it with the vector point box open to get the actual nominals.
Selecting Cad Points
Originally posted by Bill McCaffertyTry picking them in WIRE FRAME instead of surface mode.
Billsigpic
Can't prove it right now but open auto features select the type of point and in the graphics window left click and hold draw a box over intire screen to select all points then hit create and this should create all the points at one time with vector if in the point. Turn off measure, You will have to f9 them to modify the way you want. Sould be in wire frame mode.
by WingmanI have PCDMIS 3.73 CAD. I have several fan blades to inspect and the blade profile to CAD must be 0.5. OK, I simply grabbed a bunch of points on the...
10-13-2008, 11:52 AM -
by dwadeChecking a supplier program in V4.2MR1 and I am trying to check the noms on vector points back to CAD on several angled surfaces and when I check the...
07-25-2012, 08:32 AM -
by Paul SarrachJust curious, What do you prefer Vector points or surface points, and the pros and cons to them. Seems Vector points seem to have a lot of flaws. ...
04-05-2006, 03:09 PM -
by Eva HerterHowdy,
Has anyone had a problem with vector points?? When using AUTO-POINT PCDMIS does not remember or calculate the correct Vector. It...-
02-21-2013, 05:57 PM -
by Stephen1055I understand that a vector point has a vector associated with it and a surface point does not, but when would you use one rather than the other?
07-09-2014, 05:19 PM -
