Edge scanning
  • Edge scanning
    I was asked about edge scanning.
    I am using 3.7 MR1.... stable at the moment.
    Here is the deal.
    An open scan. Changing the points to edge points.
    To establish an open scan, you need a start, direction & end point. Here is the issue with 'edge' points. The start point needs 3 samples on the SURFACE then one on the edge. The direction point needs 1 hit on the edge ONLY. The end point needs 3 samples on the surface, then one on the edge.
    NOTE: The samples you take for these points only register by sound!!! No other indication says they are taken until you hit the third sample hit, so make the points spread so it can read the surface
    864-577-8317
    what was the question?
      The problem was started as the machine driving to Hong Kong when the scan started. The thought was whether it was a software/controller issue.
      Been there, done that. This is a 30 grey hair issue that I had a while back & solved. Just posting it for info's sake & to share.
      • jonny
        Edge Scan
        by jonny
        I am trying to perform an edge scan, but the machine keeps crashing when I do so. I believe the main reason is my inexperience with a CMM, so I hope...
        03-22-2006, 11:30 AM
      • Liambo734
        Finding an edge
        by Liambo734
        I have a callout which is the height of a raw edge. One side of the edge is a plane, the other side is a free surface. The edge is the intersection between...
        12-19-2013, 11:59 AM
      • psalm2
        scan liner open edge
        by psalm2
        Im trying to scan a edge on a surface thats on a curve. Ive had problems before on edge scans. Seems like I can never get the parameters right. Can someone...
        08-23-2006, 02:22 PM
      • Mansukh
        Scanning on cad model
        by Mansukh
        I got casting part to measure profile at on Edge of thickness about 5 mm. I tried to use open line scaning and the select the surfaces on the edge (Edge...
        10-15-2009, 07:33 AM
      • Matthew D. Hoedeman
        Edge Point
        by Matthew D. Hoedeman
        OK, I know I am going to be in for a lot of ribbing on this one, but here goes:
        I have a part (no fixture yet) that I have to do an iterative...
        06-21-2007, 08:46 AM
