The default file setting in the "Edit Window Print Setup" box is to the folder that the program came from. When I change the folder that it saves to, it works for that execution, but when I exit out of PC-DMIS It automatically resets back to the default settings. Does anyone know how to make these settings stick?
Saving the PDF report files
Originally posted by cappelThe default file setting in the "Edit Window Print Setup" box is to the folder that the program came from. When I change the folder that it saves to, it works for that execution, but when I exit out of PC-DMIS It automatically resets back to the default settings. Does anyone know how to make these settings stick?sigpic
Isn't it the "Report Window Print Setup"? I use V4.1 and it is called that in my case.
I had a similar issue with V4.0. V4.1 seems to have fixed that.
OK, I think that I at least need clarification of your question. This is how I am reading it.
You create a program. You go file - edit window print options - you select file and the type of file - you browse to find the path where you want the results saved - You click save - you click ok - you save the program. Then you close the program.
Here is where I need clarification.
When you re-open the same program has the path changed back to default?
OR...
When you create a new program the path has changed back to the default?
If it is the first case, you have a problem and I don't know how to fix it.
If it is the second case, it is opening in the default directory as set up previoulsy. You can change this directory but it is same directory as you save and open programs to/from. So, either you will have to change where it looks for saving/opening programs or you will have to go in and change the path in the print window all the time.
What would you like to do?
by QuickStickzI am trying to print .pdf files to a path on my PC. This was working fine but now even though the path in the dialog box is as I want it the print function...
Channel: PC-DMIS NC
10-07-2019, 01:49 PM -
by emkay4597When I insert print commands in my program, it works fine, it's just that I'd prefer the reports to be saved (pdf's) in a folder other than the same folder...
09-30-2013, 05:40 PM -
by JigneshI feel I would suppose to click file and report window set up to save measurements of report window. It could have already been setup and I would just...
02-13-2016, 08:30 AM -
by NMC_CMMWe recently changed versions from 2017 MR2 to 2019 MR 1 and I've been able to tweak just about everything to the way we like it with the exception of...
01-04-2021, 12:42 PM -
by mcdavidWhen I create a marked set there is an option to create a PDF instead of printing. I have had two problems trying to do this. When I change the directory...
11-17-2011, 03:38 PM -
