switching a program with a scan from TP20 to LSPX1
  • switching a program with a scan from TP20 to LSPX1
    I have many programs that were written using a PH10 with a TP20 that have scans.
    we now have a CMM with a tesa-star LSPX1 that has analog scaning.
    i'm pretty sure i can use the same programs, but will i have to rewrite all the scans?
    or will they run as is? i'm guessing i would need to rewrite the scans because the probe heads are different.
    i did used a model to create the scans using cad++ 2011MR1
    and am i missing anything else for this change over ?
    i do see that it is a much larger probe and will need to be careful with clearence issues.
    thanks
    The TesaStar we had where I used to work rotates & indexes every 5°. Your PH10 every 7.5°. So if you have an old program with a 97.5°A82.5°B you will have to edit your program to the closest Tesa angle.
    DeWain Hodge
      If your scans are set to "NORMA" this means it will use touch probing every time, analog or not. You may need to change them to DEFINED or RELEARN. You should not have to re-write every scan though.
        they make then now that rotate 7.5. i hear soon they will rotate 2.5
        thanks, i will try that
          Offtopic: beware, LSPX1 needs to be calibrated often ( I do it daily), because it wont withstand even a minor collision.
          B&S One
          PC-DMIS CAD v2014
          Romer Infinity
            thanks
            • Tested
              TP20 (to) SP25
              by Tested
              I'm writing a program for a job that will run on a new CMM with a SP25. "This CMM has not even been ordered yet."
              The old CMM that I'm...
              08-05-2008, 06:28 AM
            • Tridad
              Run Away Scan
              by Tridad
              Need some Scanning help here. I’m running a BS, Global Reference XI, with a B-4 controller. The software is PC-DMIS 2011, custom built for us. Using...
              11-04-2013, 12:14 PM
            • Tested
              Scans don't run.
              by Tested
              I will try thi again. I,ve got a program that has been run many times. Today the program runs fine except it skips all scans. I have tried...
              04-03-2007, 08:37 AM
            • Tested
              SP25 vs TP20 Programing
              by Tested
              Can I program on one CMM that only has A TP20 and make this Program work on a CMM with a SP25.
              By work I mean Can I make it scan on the CMM with...
              01-26-2017, 05:54 AM
            • Willigan
              Scan with TP20?
              by Willigan
              So I need to do a patch scan to create a surface on a part and do a profile of surface dimension. The reference manual leads me to believe that all I...
              06-27-2006, 11:17 PM
