When using a print command in a program, is there a way to specify which printer to send it to? Right now it's sending to a printer that is not even setup as the default Windows printer for this workstation. The printer I want to send to IS the default Windows printer.
And I do not want to set it up in the "Edit Window Print Setup" because I'm calling the print command from a Select Case routine so the operator can choose to print, output to file, or just exit.
Any suggestions?
Here is the print command:
and here is the entire select case routine (nested in a do/until loop so the operator can choose to do both printer and file if desired):
or if anyone has a better suggestion on how to program this, I'm all ears... still learning... doing alot of this on my own by trial and error.
Thanks!
Kevin
Any suggestions?
PRINT/REPORT,TO_FILE=OFF,AUTO=1,$ TO_PRINTER=ON,DRAFTMODE=OFF,$ PREVIOUS_RUNS=DELETE_INSTANCES
DO/ C1 =COMMENT/INPUT,Choose Report Option: ,1 - Send Report to Printer ,2 - Send Report to .pdf File ,0 - No Report - Exit Program ,Type Number and Press Enter... SELECT/C1.INPUT CASE/1 PRINT/REPORT,TO_FILE=OFF,AUTO=1,$ TO_PRINTER=ON,DRAFTMODE=OFF,$ PREVIOUS_RUNS=DELETE_INSTANCES END_CASE/ CASE/2 PRINT/REPORT,TO_FILE=ON,PROMPT,$ TO_PRINTER=OFF,DRAFTMODE=OFF,$ PREVIOUS_RUNS=DELETE_INSTANCES END_CASE/ END_SELECT/ UNTIL/C1.INPUT < 1 OR C1.INPUT > 2
Thanks!
Kevin
