Help....I need to take a 360 hit scan of internal and external polygons and report the conditions graphicaly.Am having problems writing the program and reporting dimensions.
Scanning Polygons....Again
1. Put the origin at the nominal location of the polygon.
2. Figure out the nominal location of a 1 wall.
3. take a 2 pnt line on the wall and adjust nominals, vectors to correct locations.
4. If this was a 6 sided polygon, change the number of hits from 2 to 60, and answer yes to equally spacing the hits.
5. edit the pattern pasting to 60 degrees for 6 sided polygon. 5 times to rotate.
6. copy the original line that you updated to 60 hits
7. edit – paste with pattern.
8. now you will have 6 lines with 60 hits each.
9. create a feature set from the 6 lines.
10. insert a profile dimension for the feature set based on the tolerance that you need.
11. insert an analysis view for the profile dimension.sigpic
pictoral
use the rest of my previous post to fill in the blanks.Attached Filessigpic
Is this the polygon on the shaft interface of air compressor impellor?
Scan as unknown closed shape and compare to CAD - allow bestfit in rotation about centerline and 2 axis translation only.
No model
Originally posted by cmmguyIs this the polygon on the shaft interface of air compressor impellor?
Scan as unknown closed shape and compare to CAD - allow bestfit in rotation about centerline and 2 axis translation only.sigpic
Originally posted by BoomerHe doesnt have a model to use...I tried having him use a linear closed scan...but without a model to compare it to it does you no good.
He will HAVE to get at least a 2d profile from a CAD system. The polygons that I have seen usually dont have flat sides, they are radiused. If they are flats, then I guess you could measure the normally but the datuming will be very important.
I have not seen how the datum is supposed to be setup. Is it to the theoretical corners, Max Inscribed circle inside the lines....or what?
IF he has to report it "graphically" then he still has to get a CAD file or make one, regardless of anything.
by Rick KubischWould like to try to go from hole to hole
in a xy plane and instead of auto-circle feature after feature with
5 hits, I would like to measure...-
08-07-2006, 04:33 PM -
by xharpbobI'm using 2010 MR3. I have a round, flat part that I want to measure flatness of. I used Auto Plane to take 18 hits on 4 rings in a radial pattern. I...
10-12-2011, 01:15 PM -
by GalvanHi...I'm new to CMM programing and had a question. I'm currently having problems measuring a hexagon shaft using a circle as my origin for XYZ, and one...
Channel: PC-DMIS Code Samples
02-17-2012, 10:39 PM -
Help...! New to pcdmis and needing to scan or profile polygons.Past method was umess via vda files (360 hits per poly).Polygon dimensions need to be expressed...
10-05-2006, 09:32 AM -
by Jace7420I have a part with 40+ holes that I just took 3 hits on each hole as to quickly program it. I went back and changed the hits to 5 hits, but i didn't...
11-18-2008, 07:06 AM -
