Help dimensioning this feature: Profile of a Surface to Datums
  • Help dimensioning this feature: Profile of a Surface to Datums
    This is a surface on the left side of an engine block. I dont think I have ever encountered this. D and E are dowel holes on the front face...should I construct a line between the 2 dowels, call it D-E and dimension to that? Its a surface so, measure a plane, and dimension its profile back to A and D-E.....?
    Im guessing this profile controls the location of the surface because there is no definitive area that says where this surface should be.
    Browne & Sharpe Global Advantage 12|22|10
    PCD 2012 MR1 CAD++
    That is my guess not looking at the drawing. When a profile is called back to a datum it is usually form and location. Im guessing they want the surface control to the datum a plane and also controlled by the datum D-E line. How do they know where to machine or make the surface if there is no dimension where it should be? I imagine there has to be a dimension of some sort with it called back to datums
    sigpicSTANDING CORRECTED IS THE ONLY WAY I STAND
      [ATTACH=CONFIG]8731[/ATTACH]
      Mike you are correct in thinking that you need to construct a line between these two holes "D" and "E" and then call that line Datum "D - E", it will be your secondary datum and "A" will be your primary datum. Datum "D-E" is commonly refered to a "dual feature datum". You should be able to google it and find out a little more information about the datum callout.
      If there wasn't a wrong way, I would have no way at all.
        Thank ya sir..
        PCD 2012 MR1 CAD++
          And the front face is datum -A- I presume?
            Centerline of crank..running parallel with this face
            PCD 2012 MR1 CAD++
              Hi Mike,
              You may want to step up your self-education (or convince your employer to assist with this) and get ahold of some Geometric Dimensioning and Tolerancing training materials.
              We actually offer a class called Applied GD&T for PC-DMIS that is a whopper: it not only teaches you GD&T (as defined by the ASME Y14.5 standard) quite correctly but also teaches you how to use PC-DMIS to check the stuff.
              More and more industries are moving to GD&T for blueprints. You're in automotive where it's completely standard.
              It's become pretty much a required skill that to run a CMM you have to know GD&T, and not just know of it but know it well enough to explain it to people.
              • programmer
                surface profile
                by programmer
                How come when I dimension the 0.010 surface profile of the cone to datum EF its give me 3 separate results Individually? datum E is a cylinder and datum...
                11-20-2020, 10:21 AM
              • Ken8282
                FCF for surface profile
                by Ken8282
                I have a call out for a surface profile with no datums. When I dimension it out using FCF I get form only. Do I have to be using datums to get form and...
                12-21-2012, 02:15 PM
              • BANDY
                Profile question
                by BANDY
                I have a couple of different profile call outs on my B/P. On the same print there is a profile of a surface .010 to BAC then on an other surface .010...
                06-27-2007, 06:27 PM
              • oriental_sun
                Surface profile From ABC
                by oriental_sun
                Just looking for a quick opinion, I have a print that is profile of a surface from ABC. Everything on the print is drawing the Z location from datum A...
                07-08-2012, 04:03 PM
              • Jrcurve
                Profile call of datum A
                by Jrcurve
                Please help me.
                I have a profile call like as ' surface profile 0.02|B|C|' . And the arrow is pointing datum A. What does that mean?. I don't understand...
                11-23-2017, 08:59 PM
