Some of my results are inconsistent.
On one pass a threaded hole will report .025" out-tol on true position.
Measure it again, and it'll show out by .009".
I'm aligning to the part itself, using the datum features specified on the drawing. I have CAD and am using version 3.7MR3.
The main problem are the two threaded holes...especially the one farthest from the A datum. We (the engineers and I) decided to add in another datum, (D) not pictured, on the surface that this threaded hole is drilled into.
That improved the results some, but not a lot. The material is also giving us trouble. It is G10 (Epoxyglass). We decided to try to measure the threaded holes with the inserts installed and a 6-32 threaded plug run into the hole. I measure the plug as a cyl, and then I project a circle onto its surface (3.636" from B) and dimension that for TP. Still getting shaky results. Repeatability seems to be an issue. I am currently re-calibrating my tips. ( I use two during the program.)
Attached is the print:
Is there a better way to align this? The A and B datum surfaces are SMALL. A is .545" X .350" and the new D datum, into which the second threaded hole is drilled, is .472" X .350". AND both of these datum surfaces have holes drilled in them, which reduces the available real estate from which I can take hits.
This has been a pain in the ****.
Any new ideas are welcome...
The weirdest thing, is if I lay the part on a surface plate and measure the .175" basic dimension to the hole centers, it shows almost perfect (around .174 to .176). The report says that it meaured .1844" of something crazy like that. I've got a bunch of these to measure, which is why I'd like to use the CMM. The height gage and surface plate says some of my CMM numbers are not very believable. I'm confused.
