I can not seem to get the angle correct when I build an "L" shaped tool.
This is how I build...
1) TP20 - shows good in the graphic
2) 100mm ext - shows good in the graphic
3) Knuckle - shows good in the graphic
4) Tip 1.5 x 20 - shows good in the graphic
My problem is... the TIP points in the "munus Z" direction in the graphic. I need the TIP to point outward, in the "minus Y" direction in the graphic.
How do I tell the new Tool File that I want the "L" shaped tool to stick out in the 'minus Y" direction and will this show good in the graphic when I'm done?
Then, will I have trouble calibrating this new tool?
Thanks in advance.
Thanks in advance.
