Datapage Error Message
  • Datapage Error Message
    I am trying write data to a data base using data page. When it trys to write the data to the data base I get an error message that says " DATA BASE OPEN ERROR: -127" I already deleted the XSTATS.DAT file and it worked once. I change the database directory in my program and now I am getting this error. Can anyone give me a hand. I am using V3.2 Dmis and whatever version of Datapage comes with it.
    Thanks in advance.
    Kevin
    Kevin
    Do you have a database in the target directory? If not, you will get that error, you have to create a new database FIRST (with Datapage editor), it has to be there before Pcdmis tries to send it data, Pcdmis will not create it.
      Yes i created a new database in the target directory. I had the same problem when I ran the first CAP study, but now I have another cavity of the same part and I cannot get it to write.
      Kevin
        Try deleting .taf and .dbl in your database then rerun it will build new if that don't work you may have to do ASCII dump in editor. hope it helps...
        PC-DMIS CAD++ 3.7 from 4.2 MR1
