Help...! New to pcdmis and needing to scan or profile polygons.Past method was umess via vda files (360 hits per poly).Polygon dimensions need to be expressed graphically with min max and nominal dimensions shown.
Scanning Polygons
Try using a linear closed scan. Depending on the size, you will have to adjust your hit spacing to reach the 360 hits. Dimension the profile of the scan and then put in dimsion info, then create an analysis view for the scan.sigpic
Scanning start
Here is a basic setup for a scan to get you going.Attached Filessigpic
by rrowsamI'm very new to PC-DMIS and am trying to scan a relatively simple profile (view attached). I have a HP-S-X1h scanning probe and am running 2015.1....
04-10-2017, 11:55 AM -
by drako28I'm using PCDMIS Pro 4.1 just scanning a Basic line scan. When I tolerance using Min Max. It's telling me the Min and the Max is the same.
05-08-2008, 03:48 PM -
by keegoWell you guys helped me see my programming error the last time, how about this? I inserted a linear open scan and it ran great. Then on the next run,...
08-19-2010, 01:43 PM -
by MOREPOWER2ULSPX1S will not scan in analog mode. Only wants to do TTP?
01-02-2013, 12:34 PM -
I am scanning the od of a part. The first time it runs great. The next run it will start taking points around the part instead of a scan. I'm using a...
11-23-2009, 03:58 PM -
