RUNOUT vs CIRCULAR RUNOUT
  • RUNOUT vs CIRCULAR RUNOUT
    In 3.5 We Had The Runout Dimension, But In 4.1 They Call It Circular Runout Dimension. I Have A Part That I Am More Or Less Checking The Face Runout Back To A Cylinder ( Bore To Face ). I Did A Perimeter Scan And I Want To Check This Scan Back To The Cylinder. I Cannot Choose This Scan Using The Circular Runout Dimension Because It Doesn't Even Give Me The Choice In The I.d. Selection Box.
    Why Was This Changed? What Do I Select Now To Report Runout Of A Face Back To A Bore?
    PCDMIS 4.1, 3.5mr2,
    Sounds to me like your looking for perpendicularity not runout. My .02
      WBWBS
        FYI IN THE HELP FILE STATES:
        The Insert | Dimension | Runout and Total Run menu options determine the runout of the first feature with respect to the second feature (i.e., the second feature becomes the datum feature). If only one feature is selected, the origin and the work plane become the datum feature. In this case, PC-DMIS uses the position from the origin and the direction from the workplane for the datum. The text in the Edit window for the datum feature will read "THE ORIGIN".
        • Circular Runout works for circles, cones, cylinders, and spheres.
        • Total Runout works for cylinders, cones, and planes.
        This dimension type is considered one sided, meaning a single positive value tolerance is applied.
        SO I AM ASSUMING I WOULD USE TOTAL RUNOUT TO CHECK A PLANE WITH A RUNOUT FEATURE FRAME(?)
        PCDMIS 4.1, 3.5mr2,
        • keego
          Lateral Runout
          by keego
          I have a runout callout on a plane at the end of cylinder Datum_A. I constructed the plane from points taken using paste with pattern. When I select the...
          03-02-2010, 01:36 PM
        • JoBLOCK
          Runout
          by JoBLOCK
          Roughly speaking: runoutx2 = concentricity right?
          Example. round part. I am chucking on the OD checking the runout of the ID
          03-30-2009, 02:55 PM
        • John Kingston
          Total Runout
          by John Kingston
          I have a part with /TR/.010/A/B/. -A- is the plane I am leveled to in Z and my Z origin. -B- is a diameter perp. to Z. -B- is also my X,Y origin. The...
          05-29-2007, 03:12 PM
        • AuRules
          Runout
          by AuRules
          With help from you guys on my earlier thread, we went with runout.
          So I used this example
          The worst circular runout...
          04-23-2008, 04:31 PM
        • 1rejector
          Total runout from cylinder to plane
          by 1rejector
          Im checking a gear with a circular runout callout to a flat surface from a cylindrical datum.Version 4.2 MR1 does not support this usage.Any ideas?
          08-01-2008, 02:37 PM
