When I Run The 'show Path Lines' My Cad Model Becomes Transparent. If I Have A Small Part With Allot Of Scans And Move Points, It Is Very Hard To See Because You See All Your Scans Through The Part. In Older Versions You Only Saw What Was On That Side Of The Part. Does Anyone Know How To Turn The Transparency Off. I Tried The Lighting Area But It Didn't Work Either By Me Not Selecting The Right Areas Or That It Is Somewhere Different Than Here. Maybe There Is A Setting In The Editor Or Controller. Can Someone Help Me? Also, How Can You Make The Path Lines Larger In Size?
Show Path Lines And The Cad Model
CHANGING THE LINES WORKED GREAT - THE CAD DID NOT WORK IN THAT I ALREADY HAVE THIS OPTION UNCHECKED, I THINK WHAT I AM ACTUALLY ASKING FOR IS THAT THE PATH LINES ARE VISIBLE THROUGH THE CAD. THE CAD IS NOT TRANSPARENT, BUT THE PATH LINES CAN BE SEEN THROUGH THE PART. IN 3.5mr2 I COULD RUN 'SHOW PATH LINES' AND THEY WOULD ALL BE THERE BUT I COULD NOT SEE THEM THROUGH THE PART. THE WAY IT IS NOW, I SEE EVERY LINE, CIRCLE, SCAN, ETC. FROM EVERY VIEW AND THE SCREEN BECOMES VERY CONFUSING WITH ALL THE LINES BEING SHOWN. I WOULD LIKE TO HAVE THIS TURNED OFF SO THAT ONLY THE LINES VISIBLE ON THE SIDE OF THE CAD YOU ARE LOOKING AT ARE VISIBLE AND THE ONES BEHIND IT ARE HIDDEN UNTIL THE CAD IS ROTATED AROUND.sigpic
PCDMIS 4.1, 3.5mr2,
UNcheck this if you have it "on"
viewsetup>show lines over surfaces
if that isn't the fix then I would have to say the graphic card/pcdmis are choosing what to show with regard to the memory available....just my opinionsigpiccall me "Plum Crazy"....but you only go around once!
It Was Already Unchecked, But I Tried Checking It And Unchecking It But It Had No Affect On My Path Lines. There Has To Be Another Box Some Where That Is Checked That Needs To Be Unchecked, I Just Need Steered In The Right Direction
Thanks All For Your Help And If Anyone Else Has Any Suggestions I Will Sure Give Them A Try.
Is Anyone Else Experiancing This Or Am I The Only One?sigpic
PCDMIS 4.1, 3.5mr2,
by DarrollhGood morning,
I am running 2018R1. Whenever I show the path lines, I cant get rid of them. Is there a setting I missed. Its annoying.-
04-23-2019, 09:53 AM -
by Steve RHi everyone, I am having an issue with the path lines, the lines are not visible until I click on the cad model. If I generat the path lines it is...
05-11-2018, 10:20 AM -
by AuRulesIs there a hidden secret on showing path lines, that will let me show only certain portion of my part. It's a fairly large program and when I click on...
03-19-2010, 07:44 AM -
by CaemgenI searched for path lines missing, path lines and path. Get a whole lot about file tree structure nothing about my problem that I saw though.
04-07-2011, 04:08 PM -
by dmis100When you turn view path lines on they will not turn off.Reported to tech support. Issue PCD-140679 - 2018 R1 Path lines stay on has been successfully...
04-12-2018, 10:34 AM -
