How do you get the ( Insert>Report Command>External Objects) external object feature active when it shows inactive? I need to add some pictuers describing the set-up and I do not know how.
External Objects not working ?
by vektorExternal objects?? does it work as it should?
I am running 3.5mr2 and it not working
My goal is to get a picture of a Cpk diagram...-
10-10-2006, 12:12 AM -
by Allen LongWhy is my external objects grayed out under the reports tab ? It seems to me that I have used that option in previous versions to add voice instructions...
03-12-2008, 11:03 AM -
by HoodlumThe external object button is greyed out when I try to select it. I am in the command mode, but can't select it. Any thoughts?
Thanks Again.-
12-07-2009, 12:41 PM -
by AAP_CMMI insert an External Object into my Edit Window on PC-Dmis 2011 MR1...its an excel spreadsheet that i would like to have print off with the rest of the...
12-10-2019, 03:58 PM -
by RookieHaving trouble inserting some graphics into the report. The demon won't insert the .bmp pictures. INSERT-> EXTERNAL OBJECT-> CREATE FROM FILE....
05-16-2013, 08:24 AM -
