I want actual xyz measurement in an edge point. I have tried using Expression Builder but it keeps saying that it is an Invalid Expression. Any other way to do it?
Edge point actual xyz
Are you using a surface sample hit, is that why you can't get the XYZ you are looking for? If so, use GAPONLY mode when dimensioning the edge point, it in effect removes the surface variation, giving you a straight edge result.sigpic
Well, I would post this in the TIPS & DESCRIPTIONS section, but there isn't one (yet?). I have put this here in the CODE section since it will not...
Channel: PC-DMIS Code Samples
10-16-2006, 07:44 AM -
by AuRulesJust need a couple of questions answered about edge points. Never, ever used them but trying something for the boss who says this project is hot....It...
12-01-2010, 01:01 PM -
OK, I know I am going to be in for a lot of ribbing on this one, but here goes:
I have a part (no fixture yet) that I have to do an iterative...-
06-21-2007, 08:46 AM -
by miles.cGreetings ladies and gentlemen,
Heres my question. In edge points, there is a dropdown for measurement properties mode. The default is surface,...-
12-13-2017, 06:31 AM -
Good Morning Folks,
Using v3.7mr3.
Quite often, I have a need to use edge points (plastic parts).
What is...-
11-06-2006, 08:34 AM -
