I have a long part with a Datum slot on one end and a Datum hole on the other. Due to machine size limits, I can't get to both of them in one set up. My idea was to measure all of one end using some alignment holes other than the datums and then move the part and check the other end using those same alignment holes. What I don't understand is how I could use a Datum hole in the first set up and a Datum slot from the second set-up for the final dimensioning. Any ideas on how to do this? Thanks.
Alignment for very long part
It depends on what other datums you have. If the slot is a referenced datum for different features than the hole then you might be able to do some measuring. If you need both the slot and the hole to do an alignment you are most likely SOL.
You could measure it by using a created feature at a location relative to your "alignment holes" to simulate the hole datum but I wouldn't.
Originally posted by QCinTNI have a long part with a Datum slot on one end and a Datum hole on the other. Due to machine size limits, I can't get to both of them in one set up. My idea was to measure all of one end using some alignment holes other than the datums and then move the part and check the other end using those same alignment holes. What I don't understand is how I could use a Datum hole in the first set up and a Datum slot from the second set-up for the final dimensioning. Any ideas on how to do this? Thanks.sigpic"Hated by Many, Loved by Few" _ A.B. - Stone brewery
It's a basic flat sheet metal part (couple of flanges). Datum A is the main surface, B is the hole & C is the slot. Everything on the print is called out as TP 1mmc A|B|C. I was hoping, with that kind of tolerance, that I could come up with something that could merge the set-ups. Oh well. Thanks again for the responses.
Measure the first datum that you can "see". Measure the two holes that will be visible from both ends. Setup an alignment on the two holes. Report the datum feature from those interim alignment features.
Now move the part, remeasure the interim alignment features and set alignment on them like you did before moving. Recreate the first datum using the reported information from the first position. This virtual feature should be off the machine somewhere.
Now measure the second datum and establish your datum between this second measured feature and the virtual datm that you created.
If you have features on both sides of the move then you will need to be careful on how you get their information. I thought there was a "move part" feature in PCDMIS.
(or)
Buy a bigger CMM
Originally posted by Don RuggieriYou should look into the Equate alignment and/or the LeapFrog functions of PC-DMIS. I believe you can accomplish your goals with these. They do add some risk/variation to the whole process, but sometimes there is no alternative. . .
Thanks Don, I am going to add that to my collection of euphemisms.
Manager : "The customer rejected these parts you checked. What happened?"
Employee : "Gee, I don't know for certain, but I would suspect the abscence of an aggressive metrological equipment acquisition policy has necessitated the use of a procress that incorporates an unacceptabel level of risk/variation that was not noticed because of the continous throughput encouragement environment.
Big Part
WE have done this many times pretty much how cmmguy said in his above
post, use common sense when picking your virtual alignment, with the
tolerance you have, you should be fine. Also, will the part fit if you put it on a 45
degree angle, the part doesn't need to be straight on a cmm, if all the features are
on the top.Last edited by BOB PARSONS; 10-02-2006, 05:04 PM.GLOBAL FX 12-15-10
3.7MR3, XP/SP2
The equate alignment has worked well for me many times in the past. There is a potential risk/variation factor involved, but, if done correctly this should be a minimum. First, try to locate some good well defined features somewhere in the center of the part while a fair distance apart. This way, you can establish a solid temporary datum structure while measuring your part. The key is to locate features for this alignment that can be utilized in both part positions.
Basically, use these features, align measure all of the features within the envelope of the machine, move the part forward or back (depending on whichever position you choose to begin with) and then repeat the previous alignment used in the new position. You can then measure the remaining features. With all features measured, you will have a pretty screwy looking graphics window, but now, you should be able to go to the alignment menu and choose the equate function. The key here is to equate the most recent alignment to the first. This will "marry" both halves and give you something that will represent the entire part and if done correctly should appear as such in the graphic display. Now you can use your print datums to perform a final alignment which should allow you to dimension the part with a minimal amount of error. Be aware that the point data taken for the temporary alignment features must be taken very critically to reduce the margin for error.
When you have no other alternative, this is very useful, but it should only be used as a last resort due to the risk of error involved. HTHDCCFreak
Can you reach both holes if you use a star probe and a 82.5,0 and 82.5,-180 angle on your head? I have had to do this type of thing. Depending on the amount 'too long' the part is, you might be able to get them both. I have effectivly increased the 'length' of my CMM by 10 inches using this method. Sure, it sucks, but it will work.sigpic
by pezhead444I have a hole and slot in a part that are measured that are also datums and there are also a hole by each that are referenced in the GD&T to the datum...
09-13-2009, 07:36 AM -
by BitolaHello everyone,
Can you please check the attachment with 2drawings, my concern is on how to check TP of 4 10mm holes on CMM with datum...-
09-30-2013, 10:10 AM -
Good morning and Happy New Year to all the wonderful knowledgeable and helpful people here! I had my coffee already can you tell?
Anyway...-
01-05-2018, 10:51 AM -
by layout techThe Thread about datum scheme callouts got me to thinking.
What would you do?
Case in point : We have a plastic part that...-
10-06-2010, 01:32 PM -
by ErikirHow do I create this datum B?
If the GD&T is incorrect, it's easy for us to work with this customer to get it corrected.
The attached...-
05-11-2017, 01:21 PM -
