Error in best fit calculation?
  • Error in best fit calculation?
    My autocircle is getting an error in best fit calculation message?? Anyone know why and how I can fix it?
    What kind of error message ????
      Just says, "Error in best fit calculation" after the autocircle is done measuring. This came up after upgrading to v3.7MR3.
        I have seen this message when the circle being measured is an id but is set to od.
          I'm using least_sqr with an hole diameter checked (Measuring an ID). This is the first time I've seen this error come up. Any ideas?
          Could it be an alignment issue? This particular ID is part of an alignment.
            Don't want to sound like a smart a** but have you pressed F9 for this feature and checked whether it measures a stud or a hole. Obviously you must make sure the hole check is checked.
            I have made the same error and it did odd things for me too... Until I fixed it.
            Jan.
              You have probably thought of this and tried it already
              Instead of trying to fix the bad diameter delete it and create a new one.
              If all else fails ctrl/alt/delete and reboot
                deleted and created a new autocircle still gives me the message. I'm at a lost
                  Are you using sample hits?
                  Best fit or iterative need this to make a circle 3D
                    just for the heck of it, try creating a new auto circle using max inscribed and see if it gives you your error. If it doesn't, then F7 to toggle back to least squares and try again. I have had to do this before in 3.7 for something very similar, I don't know why it worked, but, it did the trick. I have also had to run the hole in offline mode before also.
                    I know it sounds hokey, but, that is what I had to do. HTH
                    DCCFreak
                      I had to turn off the use theo and it worked afterwards.
                      Jim Jewell
