I am running 2009 MR1. As happens with pc-dmis quirks, something new arises that has never been seen before. While executing a lengthy program my desktop went into black screen mode, nothing new there, just wiggle the mouse and everything comes back. Not this time. When everything came back, I had my report centered on the whole screen with my edit window reduced to a small 3x4 inch box. I let the program finish and when it did everything popped back to normal; the screen divided by my edit window on the left half and my report/graphic option on the right. Closed the program and opened the next one I was going to use. All looked normal until I hit execute. Back came the same scenario with the report/graphic centered on the whole screen and my edit window reduced to a small rectangle. I did a cancel and the whole normal view returned. Tried execute again, same thing. Rebooted everything to see if that would resolve the problem. It did not. Has anyone experience anything like this before? I need access to my normal edit window and normal display. Any help or direction is most appreciated, its Monday morning and I have work to get done. Thanks in advance.
Help, don't know what happened to edit window but need to fix it.
If it is "normal" when you are NOT running a program, simply SAVE that WINDOW LAYOUT. Then, run a program, while it is running, click on the STOP button on the execute mode window. THEN, while it is STOPPED, recall the layout you just saved.sigpic
in addition to Matt's advice, (not sure if this was in v2009) but if you F5, and tick "use program layout for execution" you should be good to go once satisfied with your windows. (USUALLY even w/dual monitors) You might be able to apply via Settings Editor as well.
Originally posted by sealevel View Postin addition to Matt's advice, (not sure if this was in v2009) but if you F5, and tick "use program layout for execution" you should be good to go once satisfied with your windows. (USUALLY even w/dual monitors) You might be able to apply via Settings Editor as well.
Jim
by fatso666Our Status Window used to display only while Executing. Now it doesn't. I have checked VIEW/OTHER WINDOWS/STATUS WINDOW, and now it only displays WHILE...
06-30-2015, 09:14 PM -
by johnPSometimes the edit window mysteriously changes to where I cannot see the end of the file even when I scroll all the way down. I have tried closing it...
03-10-2010, 10:19 AM -
by Lee JohnsonVer 2015 latest release last week using it today had a crash and my edit window is gone .. checked, all the boxes are checked but there is nothing there....
08-04-2016, 06:56 PM -
by RSNICKERThis morning I was running a program and all of the sudden all of my windows and toolbars turned off. I restarted the computer and I'm able to get everything...
02-24-2009, 02:11 PM -
by ErikirIf I edit a program (change a move speed, for example), then execute it, the edit window goes blank while the programming is running.
If I edit-->preferences-->edit...-
05-23-2013, 10:40 AM -
