V4.1 Install #2
  • V4.1 Install #2
    Installing at 2nd seat, getting numerous errors related to Dll.
    Unable to register Dll:appevents.ocx Dll Register Server returned -2147220992
    Unable to register Dll:machevents.ocx Dll Register Server returned -2147220992
    Unable to register Dllartevents.ocx Dll Register Server returned -2147220992
    Unable to register Dll:SPCChartAreaCtrl.ocx Dll Register Server returned -2147220991
    Unable to register Dll:SPCMonitorCtrl.ocx Dll Register Server returned -2147220991
    Unable to register DllimAnalysisActiveX.ocx Dll Register Server returned -2147220991
    Unable to register DllimensionReportControls.ocx Dll Register Server returned -2147220991
    Unable to register Dll:FutureAnalysisActiveX.ocx Dll Register Server returned -2147220991
    Unable to register Dll:ReportingThumb.dll Dll Register Server returned -2147024891
    Unable to register Dll:BFANALYSISACTIVEX.ocx Dll Register Server returned -2147024891
    Probably all related to the same thing, would appreciate any help steering me in the right direction.
    TIA
    Brian
    I renamed them all with an _1 ( they are listed in the same directory as where you saved the 4.1 download ) and have not encountered them since. Cmm seems to be running OK. Loaded same download on off-line with no experiences(?) Go figure
    PCDMIS 4.1, 3.5mr2,
      Thanks!!!
      That did it, working fine now. Appreciate the help.
        4.1 has a new feature which requires new registry values to be created from what I understand in the documentation every time it starts up. I also had this issue a couple of weeks ago, and found that once I reset the windows user permissions for that particular user id, the problem went away. I believe these dynamic link libraries which require the registration influence some of the reporting features in 4.1.
        Other than some of the reporting capabilities being affected, I did not find any other issues. I too renamed these files in the beginning, but, then after several days, I found that there started to be an issue with PC-DMIS freezing up and not starting. I switched the .dll file names back to what they were, and then of course the errors started again. I have administrator rights on my puters and I noticed that if I used my logon, there were no errors so I modified the generic user permissions and I haven't seen an issue since. Just my .02
        DCCFreak
        • boximus
          4.1 upgrade issue
          by boximus
          Recently upgraded 3 CMMs from 3.5/3.7 to 4.1. Two of the three upgraded with few or no issues and are working fine. The third was left alone for a few...
          09-26-2006, 09:43 AM
        • Cookie
          unable to register
          by Cookie
          Found this in the threads. Solved my problem of why my probe measurements would not take on the B&S with 4.1 we got in.
          Thanks...
          08-24-2010, 02:30 PM
        • dccfreak
          Has anyone had troubles installing 4.1?
          by dccfreak
          I have installed 4.1 and I keep getting these .dll failed to load errors. There are about 4 or 5 of them that come up on install completion, then when...
          08-30-2006, 12:41 PM
        • willydog
          error on start-up
          by willydog
          when I go to start up pcdmis 4.1 I get "unable to register dll:" and Dll RegisterServer -2147220992 errors.
          It does seem to run okay...
          01-12-2007, 12:21 PM
        • RussL
          dll error
          by RussL
          V3.7 MR-2 - XP SP2 + hot fix.
          I have been searching, can not find a post I had thought was posted in regards to a help file .dll.
          Problem...
          04-09-2007, 12:11 PM
