Trying to install Version 4.1, currently running Version 3.5MR2. Followed the examples that I found here, copied existing directory to new directory, then installed V4.1 over new directory. I setup an icon on my desktop, linked to pcdlrn.exe and then double clicked, it starts to run, brings up the EMS advertisement, then PC-DMIS 4.1 desktop but does nothing after that. Any suggestions?
V4.1 Install #1
How did you create the shortcut? Did you drag the "ONLINE" icon to the desktop or did you right-click on the desktop and creat a new shortcut, then track it down from there?
Try the DRAG option. IF you did it that way, I am out of ideas (been a LONG day/week).sigpic
Maybe it is! V3.7MR3 takes FREAKING forever to load. V3.5, POP- open in less than 7 seconds or so, V3.7 takes almost a minute (or even more, depending on what esle you are doing) and it does NOT have a splash screen so you know it is doing something. Next thing to check is, ARE YOU running 2 instances of Pcdmis? If you clicked on it to begin with and didn't see anything, did you click on it again and it is now locked trying to open it twice? Also, was there any other icon (like STARTUP, maybe) in the start menu? If there is, you have to do that the first time before you can do the ONLINE.sigpic
Originally posted by Matthew D. HoedemanMaybe it is! V3.7MR3 takes FREAKING forever to load. V3.5, POP- open in less than 7 seconds or so, V3.7 takes almost a minute (or even more, depending on what esle you are doing) and it does NOT have a splash screen so you know it is doing something. Next thing to check is, ARE YOU running 2 instances of Pcdmis? If you clicked on it to begin with and didn't see anything, did you click on it again and it is now locked trying to open it twice? Also, was there any other icon (like STARTUP, maybe) in the start menu? If there is, you have to do that the first time before you can do the ONLINE.
Originally posted by GoodluckThat is why I always single click to highlight the shortcut and then hit "enter". That way I know for sure I have started it rather than second guessing myself "did I double click fast enough, did I double click or single click?"sigpic
Originally posted by Matthew D. HoedemanI put my shortcuts on the shortcut bar, all activated by a single click. Pcdmis, Geomagic, Datapage, Cadkey and a HOST of others. 29 icons in the shortcut bar at present. I downloaded an ICON editor and made UNIQUE icons for each version of Pcdmis, including the version in the icon. Makes it easy to get the one I want.
XP - just wanted to put that in the post one more time.
Originally posted by GoodluckYeah, I did that for some stuff that I use a lot. Of course that is on my desktop running windows 2000. Are you running XP? Can you do that with XP? My CMM computer runs XP and it is about the only computer I ever use with XP on it so I'm not to good at finding my way around XP.
XP - just wanted to put that in the post one more time.sigpic
Click - DoubleClick - DoubleDoubleClick - ClickEnter
I'm pretty sure I got that part OK. It's repeated this a half dozen times, it has been a half hour since I last DOUBLE CLICKED, still nothing. I'm running Microsoft Windows XP Professional Version 2002, Service Pack 2 on a Dell Workstation PWS360, Pentium 4, 3.40GHz, 2.00 GB RAM. This should be sufficient. Any other ideas?
The hotfix from the Wilcox Site is here:
http://www.wilcoxassoc.com/Downloads/hotfix.htm
I don't know if it will solve Brian's particular problem though. But it mgiht be worth a shot.Jared Hess - Techwriter @ WAI
by cmcculloughHas anyone ever tried installing PC-DMIS as a unassisted installation?
06-17-2008, 03:39 PM -
So I have installed both 4.1 and 4.2MR1 and everything is fine. However I'm trying to follow the slick approach outlined here and quoted here:
09-10-2007, 01:29 PM -
by jroyleIs there a way to move my software to a new workstation? I have a customer that is running 4.2, and the workstation running their software died. I'm...
10-22-2007, 07:14 PM -
by Marty Schwabok I am shure this is my fault. I installed 4.1 this morning. I renamed my folder to save the previous version so it would not be lost. It was 3.7 mr3....
08-07-2006, 11:06 AM -
by gdrive001seem to have lost the ability to pull any help pages in pcdmis 4.1
was trying to train a new guy here and whenever i click in the help files on...-
06-18-2008, 06:34 PM -
