Dimensions Color
  • Dimensions Color
    Hello Everyone;
    In the PC-DMIS VER 3.7 Release2 sample print out below.
    I have what looks like a simple problem and I did what ever I could but could'nt figure it out.
    I need assistance on how to change the color of a out of tolerance generic created dimesion DIM WALL THICKNESS (please see sample below) from black to red.
    All other dimensions are ok, that is, blue in tolerance and red out of tolerance and this is what I would prefer the print out to look like.
    thanking in advance for the help.
    Musid
    DIM INNER DIAMETER= LOCATION OF CIRCLE CIR7 UNITS=IN ,$
    AX MEAS NOMINAL +TOL -TOL MAX MIN DEV OUTTOL
    D 15.00200 15.00000 0.00100 0.00100 15.00387 14.99987 0.00200 0.00100 -------->
    END OF DIMENSION INNER DIAMETER
    DIM WT1= 2D DISTANCE FROM LINE L1 TO CIRCLE CIR8 PAR TO XAXIS, SUB_RADIUS UNITS=IN ,$
    M 1.45446 1.45681 0.00300 0.00300 1.45489 1.45403 -0.00234 0.00000 #--------
    DIM WT4= 2D DISTANCE FROM LINE L4 TO CIRCLE CIR18 PERP TO XAXIS, SUB_RADIUS UNITS=IN ,$
    M 1.45726 1.45700 0.00300 0.00300 1.45773 1.45679 0.00026 0.00000 ----#----
    ASSIGN/V1 = MAX(ARRAY(WT1.MEAS,WT2.MEAS,WT3.MEAS,WT4.MEAS))-MIN(ARRAY(WT1.MEAS,WT2.MEAS,WT3.MEAS,WT4.MEAS))
    F1 =GENERIC/POINT,DEPENDENT,RECT,$
    NOM/XYZ,0,29.15763,30.6325,$
    MEAS/XYZ,V1,29.24348,40.72944,$
    NOM/IJK,-0.00008,0.00004,1,$
    MEAS/IJK,-0.00008,0.00004,1
    DIM WALL THICKNESS= LOCATION OF POINT F1 UNITS=IN ,$
    X 0.00358 0.00000 0.00300 0.00000 0.00358 0.00358 0.00358 0.00058 -------->
    END OF DIMENSION WALL THICKNESS
    Edit
    Preferences
    Edit Window Colors
    This Should Get You Where You Need To Be.
    Many Different Options, Just Find What You Want To Change,
    And Change It.
      thank you I did that one.
      musid
