should the theoreticals (x,y,z) be satisfied when calibrating probe tips specially on a 5way center?
calibrating probe tips in a 5way center
I have seen a TP-20 5-way on the probe build choices.
Other than that, it sounds like one of those reality shows, or, or, or,.....something to do with farm animals.
PLEASE do clarify?
http://baggy3.info/2centani.gif
The theoreticals for any tip configuration are not nearly as important as the standard deviation. I was told in class you should never accept deviation greater than .0004". One thing I have found useful whenever I am unsure of a tip is the "Qualification Check" box of the calibration window that comes up after you click "Measure". When you check this box the CMM runs thru the calibration cycle, but does not alter the probe data, instead it reports what the sphere checked. This gives you a good idea of how accurate your probe is. If you want to know more about it's accuracy you need to check other types of features created from standards of known value, (gage blocks, set rings, your master part, [you do have a master part don't you? It is a great way to keep up with machine!], etc.)
As the others said, more info would help us to narrow in on your problem. HTHsigpic"Hated by Many, Loved by Few" _ A.B. - Stone brewery
by sscarpielloGreetings,
I am having an issue with the LEITZ_LSPX1H_T, head and a star configuration probe. When I go to calibrate all the angles used...-
08-17-2017, 08:30 PM -
by SekharNeed help.
I need to measure the z height of circlip grove. I use the star probe tip number 4 for measure the z distance. But the result...-
07-16-2016, 10:06 PM -
by mbattenHello,
Does anyone know if there's a way to set the calibration limits in the Probe Setup window on a per-tip basis? I've been trying off...-
06-25-2021, 02:26 PM -
by SluggerHey guys, not new to CMM's, just star probes. I had to run a program that had a star probe in it, so upon calibrating it I ran into issues. The probe...
09-13-2015, 01:50 PM -
by josh_haighI have recently purchased a 5 way star probe and am having difficulties qualifying it.
My current set up is as follows:
04-28-2011, 05:58 AM -
