Angle plane to plane
  • Angle plane to plane
    Hi everyone
    Running pcdmis v3:7. I need to Measure the angle of two planes. The angle in question is a clip that is fitted to a compt at 90deg
    The angle when measured on a shadow graph is 95deg but when I measure on CMM I get 85. Why? And how do I get the angle to match the shadow graph
    Post your code.
    Probitas laudatur, et alget.
    Hang on to your butts!
      in later versions you can type in nominal angle and Demon will oblige. Or you can jasper the dimension settings (F5) for 0-360 or 0-180. There is also a question of feature to feature (the angle of two planes) OR angle of plane (feature) to axis. (maybe will give you the relief you seek)
        Originally posted by cjtronetti View Post
        Post your code.
        What do you mean post your code?
          feature to feature still give me 85° .... I will try the 0-360 or 0-180 and let you know
            check to make sure you are checking a 3d angle and not 2d
            PC-DMIS CAD++ 4.3 MR1
              Are you getting the correct angle? (95+85=180)
              PC-DMIS CAD++ 2o19 R1 SP9
                im getting 85, but i need to show 95 on the screen
                  If you dimension PL1 to PL2, try to dim PL2 to PL1... Or create a reverse plane from on of them.
                      When you create the angle on earlier versions lke 3.7 it by default gives you the 'true' angle, you can toggle this to the 'complementary' angle using the F7 or F8 key. Somewhere in the dimension header there will be the word 'True', put the cursor on this and press F7 to toggle it to the complementary angle.
                        F7 or F8 dont work. Anychance of a screen shot
                          No, because I don't have a version to hand which had this method.
                          If you post the code of your angle dimension I'll highlight where you need to change it.
                            ignore previous post. thanks NinjaBadjer. CMM returned the angle i wanted
                              All done thankyou
                              • Rideslow
                                How do I get the correct angle?
                                by Rideslow
                                How do I get the angle between 2 planes? One of them is nice and flat, the other one is pretty twisted. As am I right now......Do I have to construct...
                                03-29-2009, 04:34 PM
                              • mdobb829
                                Reported Angle
                                by mdobb829
                                Can anyone tell me how I can force a reported ANGLE to the angle call out on the print? I have a 15° angle call out on the print. When I ask for the...
                                08-01-2008, 04:01 PM
                              • Londonjr
                                Inclusive angle
                                by Londonjr
                                How would I determine an inclusive angle? I am measuring a cone with a very minimal plane at the top of the part. (Maybe .002 land) 100 deg +/- 1 deg...
                                03-23-2016, 10:37 AM
                              • CFisher
                                Polar Ange vs Regular Angle
                                by CFisher
                                Hopefully there's enough information here to illustrate what I'm talking about. Using 2010SP2 currently with a CAD model. I'm trying to verify the 35°...
                                02-07-2011, 01:11 PM
                              • TomCat
                                how do i find this angle?
                                by TomCat
                                i am very new to pc dmis and cmms in general. just got thrown into this on monday. how would i go about finding this angle? i have 2 planes picked ( the...
                                12-05-2018, 03:02 PM
