I plan to use an iterative alignment at the start of a program that uses Cad. I need to first load an external fixture alignment at the start of the program, the next alignment will then be the iterative and it will recall the fixture alignment. The reason I ask is I only ever recalled the startup alignment into an iterative alignment in the past and I wondered if this new method would cause me any issues. Thanks.
Iterative Alignment Question
Iterative alignments are relative to your actual noms. Your fixture should be identical to this datum structure if you're using the external alignment.I used to be high on life but I built up a tolerance.
Originally posted by Underspec View PostIterative alignments are relative to your actual noms. Your fixture should be identical to this datum structure if you're using the external alignment.3.7mr3CAD++ / 2011mr1CAD++/2012mr1CAD++/QUINDOS7
I do this in every program. When you make your fixture alignment do the following:
1) Align to your fixture
2) create generic features to define a coordinate system for your current alignment
3) Do a manual iterative alignment to your part
4) report out the location and orientation of your previously created generic features.This will give you the exact translations and rotations required to transform from your fixture alignment to the part iterative alignment.
5) Go back to your alignment from step #1 and input these translations and rotations into the alignment.
6) Delete the iterative alignment and all of the generic features.
This will leave you with a fixture alignment that will get you really close to where you want to end up after your iterative alignment. Now recall that alignment in your iterative alignment program and your first iteration should already be close enough that it can run through with a pretty close prehit and retract setting. From there you should be able to converge to a very accurate alignment within 3 iterations.2013MR1 SP6
Originally posted by DaSalo View PostI do this in every program. When you make your fixture alignment do the following:
This will leave you with a fixture alignment that will get you really close to where you want to end up after your iterative alignment. Now recall that alignment in your iterative alignment program and your first iteration should already be close enough that it can run through with a pretty close prehit and retract setting. From there you should be able to converge to a very accurate alignment within 3 iterations.3.7mr3CAD++ / 2011mr1CAD++/2012mr1CAD++/QUINDOS7
How can you use iterative to create an external fixture alignment? If I were to pick the points from the CAD then do an iterative, the vectors for the...
01-08-2015, 08:56 AM -
by gszpotI don't use iterative alignments very often, and am having a small problem. My part does not have any flat surfaces or straight lines to use for a conventional...
06-13-2019, 04:10 PM -
by rerun_livesOk Guru's, Is there a way I can set up a fixture that will hold my part-aka. setup the fixture at the beginning of my program and after that set up an...
06-26-2008, 12:45 PM -
Hi Everyone
Just some advice and information on what you guys do when you use fixtures and external alignments.
At the moment...-
05-01-2018, 05:56 AM -
I got this one program that uses iterative alignment and whenever i try to execute just one feature of the alignment (cylinder for datum B and/or C),...
10-03-2014, 10:16 AM -
