Good morning. I am confused about working plane. My question is set up working plane by the machine 's axis or X,Y,Z from Cad model ?
Thanks in advance
You start out by going to your "setup Options" Part/CMM" "Part Setup" After that the working plane is whatever plane you are approaching the part in with the probe. Does that make sense?
Work plane CAN be kind of hard to explain, but if you 'get it', then it is easy, if not, it will be hard:
The workplane for a feature is the plane it exists in, for example, a circle is a round feature, if you can see the round shape of the circle from X-, then it is in the X- workplane.
I'm measuring a block that should be ground almost true. I took one plane on one area of the ground surface (We'll call this plane A). Then I measured...
Currently am running PC-DMIS CAD++ 2016.0. I have probed a plane but would like to construct a plane based on the high points; as if it was sitting on...
