Print twice via print command(s) does not work...
  • Print twice via print command(s) does not work...
    I know this has been discussed before, but I don;t know that I saw a resolution to the problem so I bring it up again.
    PRINT/REPORT,EXEC MODE=END,$              TO_FILE=ON,PROMPT,$
                  TO_PRINTER=OFF,$
                  REPORT_THEORETICALS=NONE,REPORT_FEATURE_WITH_DIMENSIONS=NO,$
    PRINTREPORT =COMMENT/YESNO,NO,FULL SCREEN=YES,AUTO-CONTINUE=NO,
                DO YOU WANT TO PRINT A HARD COPY OF THE REPORT?
                IF_GOTO/PRINTREPORT.INPUT=="NO",GOTO = NOPRINT
                  TO_FILE=OFF,PROMPT,$
                  TO_PRINTER=ON,$
    NOPRINT    =LABEL/
    I am trying to set up print commands such that the first one prints to pdf and then the operator is asked if they would like a hard copy. Upon running the code, PC-DMIS runs right past it like it wasn't even there??? This happens when the program is run normally and/or when run using marked sets.
    Anyone got a fix??
    The PRINT command updates the internals to the current command in the part program. So there is nothing left to print with the 2nd one. You may be able to have 2 PRINT commands wrapped inside an IF/ELSE statement. One to print to PDF, the other to print to PDF & printer based on the COMMENT/YESNO. Never tried that though.
      Just fiddled with it and found something strange... I made the code "PRINT/REPORT,EXEC" twice. Then instead of pushing F9 I went to File, Printing, Report window Setup. Both print codes say No print but taking the long way to it it said yes to the print.
        Don't "delete instances"
          Suggested on the other site as well. I tried it and it does not print a paper copy.
                        TO_PRINTER=OFF,$
                        PREVIOUS_RUNS=KEEP_INSTANCES
                        TO_PRINTER=ON,$
          NOPRINT    =LABEL/
            Bet it will not print if you take the long way and say no print. Even if the print code is on.
              James try this:
              Before PRINTREPORT comment type:
              ASSIGN / PRINTREPORT.INPUT="YES"
              This should reset your input to yes, if the last time you answered this question it was a "no" then it will save it as a no. I hope this helps. Also, you may want to put the comment before the print command. I've found that, for some reason, putting comments directly after a print command skips the comment.
              If there wasn't a wrong way, I would have no way at all.
                Seen this as well, is there no way to print 2 copies of the report unless I do it manually?
                PC-DMIS CAD++ 2o19 R1 SP6
                  this sets a 4 way option
                  it has worked for me
                  PART NAME  :  12J123
                  REV NUMBER :  ENTER REV # FROM PRINT
                  SER NUMBER :  QA-191
                  STATS COUNT : 1
                  STARTUP    =ALIGNMENT/START,RECALL:USE_PART_SETUP,LIST=YES
                              ALIGNMENT/END
                              MODE/MANUAL
                              PREHIT/0.2
                              RETRACT/0.2
                              CHECK/1,1
                              MOVESPEED/ 50
                              FORMAT/TEXT,OPTIONS, ,HEADINGS,SYMBOLS, ;MEAS,NOM,DEV,TOL,OUTTOL, ,
                              OPERATOR SETUP NOTES
                              GOTO/SKIPPIC
                  $$ NO,
                              PLACE PICTURE HERE
                  SKIPPIC    =LABEL/
                              LOADPROBE/REF_PROBE
                              TIP/TIP1, SHANKIJK=0, 0, 1, ANGLE=0
                  $$ NO,
                              x
                              x
                              x
                              x  program section
                              x
                              x
                              MODE/DCC
                  CIR1       =FEAT/CONTACT/CIRCLE/DEFAULT,CARTESIAN,IN,LEAST_SQR
                              THEO/<5.5015,-13.9555,-19>,<0,0,1>,13
                              ACTL/<5.5015,-13.9555,-19>,<0,0,1>,13
                              TARG/<5.5015,-13.9555,-19>,<0,0,1>
                              START ANG=0,END ANG=360
                              ANGLE VEC=<0,0,1>
                              DIRECTION=CCW
                              SHOW FEATURE PARAMETERS=NO
                              SHOW CONTACT PARAMETERS=YES
                                NUMHITS=12,DEPTH=0,PITCH=0
                                SAMPLE HITS=0,SPACER=0
                                AVOIDANCE MOVE=NO,DISTANCE=0
                              SHOW HITS=NO
                  CIR2       =FEAT/CONTACT/CIRCLE/DEFAULT,CARTESIAN,IN,LEAST_SQR
                              THEO/<5.5015,-13.9555,-19>,<0,0,1>,11
                              ACTL/<5.5015,-13.9555,-19>,<0,0,1>,11
                              ANGLE VEC=<0,0,1>
                              DIRECTION=CCW
                              SHOW HITS=NO
                  C1         =COMMENT/INPUT,NO,FULL SCREEN=NO,
                              PLEASE ENTER A ORDER NUMBER FOR THIS JOB
                              EXAMPLE   103049998
                              ASSIGN/ORNUM1=C1.INPUT
                  C2         =COMMENT/INPUT,NO,FULL SCREEN=NO,
                              PLEASE ENTER A SERIAL NUMBER FOR THIS PART
                              EXAMPLE  1
                              ASSIGN/SERNUM1=C2.INPUT
                              COMMENT/REPT,
                              COMMENT/REPT,
                              "ORDER NUMBER:  "  + ORNUM1 +"          SERIAL NUMBER:  "+ SERNUM1
                              ASSIGN/QA1=STR(GETTEXT(193,1,{FILEHEDR}))
                              COMMENT/REPT,
                              "CMM OUTPUT IS MADE TO:  "  + QA1
                  $$ NO,
                              OUTPUT SECTION OF THR REPORT
                  DIM LOC1= LOCATION OF CIRCLE CIR1  UNITS=IN ,$
                  GRAPH=OFF  TEXT=OFF  MULT=10.00  OUTPUT=BOTH  HALF ANGLE=NO
                  AX       MEAS    NOMINAL        DEV       +TOL       -TOL     OUTTOL
                  X       5.5015     5.5015     0.0000     0.0020     0.0020     0.0000 ----#----
                  Y     -13.9555   -13.9555     0.0000     0.0020     0.0020     0.0000 ----#----
                  Z     -19.0000   -19.0000     0.0000     0.0020     0.0020     0.0000 ----#----
                  D      13.0000    13.0000     0.0000     0.0020     0.0020     0.0000 ----#----
                  RN      0.0000     0.0000     0.0000     0.0020     0.0000     0.0000 #--------
                  END OF DIMENSION LOC1
                  DIM LOC2= LOCATION OF CIRCLE CIR2  UNITS=IN ,$
                  D      11.0000    11.0000     0.0000     0.0020     0.0020     0.0000 ----#----
                  END OF DIMENSION LOC2
                  $$ NO,
                              OPEN REPORT WINDOW AND REVEIW RESULTS.
                              IF YOU WISH TO STOP CLICK CANCEL
                  C3         =COMMENT/INPUT,NO,FULL SCREEN=NO,
                              PLEASE TYPE ANY COMMENTS AT THIS TIME
                              COMMENTS WILL BE ENTERED AT THE END OF THE REPORT
                              ASSIGN/COMM1=C3.INPUT
                              COMMENT/REPT,
                              "~~4  OPERATOR NOTES: " +COMM1
                  C4         =COMMENT/INPUT,NO,FULL SCREEN=NO,
                              ENTER  1  FOR PRINTER ONLY
                              ENTER  2  FOR SAVE FILE ONLY
                              ENTER  3  FOR PRINTER AND SAVE FILE
                              ENTER  0  TO QUIT OR CLICK CANCEL
                              ASSIGN/PART=STR(GETTEXT(191,1,{FILEHEDR}))
                              ASSIGN/FILESTORLOC="C:\PC_DMIS\NON_GEARING\REPORTS\ "
                              ASSIGN/FILENAME=PART+"-"+ORNUM1+"-"+SERNUM1+".PDF"
                              ASSIGN/VAL_FILE=FILESTORLOC+FILENAME
                              ASSIGN/V1=0
                              ASSIGN/V1=0
                              IF/C4.INPUT == 1
                                TO_FILE=OFF,OVERWRITE=VAL_FILE,$
                                TO_PRINTER=ON,$
                              END_IF/
                              IF/C4.INPUT == 2
                                TO_FILE=ON,OVERWRITE=VAL_FILE,$
                                TO_PRINTER=OFF,$
                              END_IF/
                              IF/C4.INPUT == 3
                                TO_PRINTER=ON,$
                              END_IF/
                                TO_PRINTER=OFF,$
                  AL
                  "I am trying to set up print commands such that the first one prints to pdf and then the operator is asked if they would like a hard copy."
                  or were you looking for two hard copy ?
                  sigpic Now I see it from your prospective.
                    Would this help, I apologize if the code doesn't format correctly here.
                    C2         =COMMENT/YESNO,NO,FULL SCREEN=NO,AUTO-CONTINUE=NO,
                                Would you like to print a hard copy.
                                ASSIGN/PDFNAME="G:\DNC\CMM\NC01704\Reports\\TX-112A-00_"+JOB+"_"+SERNO+".PDF"
                                IF_GOTO/C2.INPUT=="YES",GOTO = WHOLE_PRINT
                                  TO_FILE=ON,OVERWRITE=PDFNAME,$
                                  TO_PRINTER=OFF,$
                                  TO_DMIS_REPORT=OFF,FILE_OPTION=OVERWRITE,FILENAME=,$
                                GOTO/ENDOFPROGRAM
                    WHOLE_PRINT=LABEL/
                                  TO_PRINTER=ON,$
                    ENDOFPROGRAM=LABEL/
                      PART NAME  :  12J123
                      SER NUMBER :  QA-191
                      STATS COUNT : 1
                                  ALIGNMENT/END
                                  MODE/MANUAL
                                  PREHIT/0.2
                                  RETRACT/0.2
                                  CHECK/1,1
                                  MOVESPEED/ 50
                                  GOTO/SKIPPIC
                      $$ NO,
                                  PLACE PICTURE HERE
                      SKIPPIC    =LABEL/
                                  LOADPROBE/REF_PROBE
                      $$ NO,
                                  x
                                  x
                                  x
                                  x  program section
                                  x
                                  x
                                  MODE/DCC
                                  ANGLE VEC=<0,0,1>
                                  DIRECTION=CCW
                                  SHOW HITS=NO
                                  ANGLE VEC=<0,0,1>
                                  DIRECTION=CCW
                                  SHOW HITS=NO
                                  EXAMPLE   103049998
                                  EXAMPLE  1
                                  COMMENT/REPT,
                                  COMMENT/REPT,
                                  COMMENT/REPT,
                      $$ NO,
                      $$ NO,
                                  COMMENT/REPT,
                                  ASSIGN/V1=0
                                  ASSIGN/V1=0
                                  IF/C4.INPUT == 1
                                    TO_PRINTER=ON,$
                                  END_IF/
                                  IF/C4.INPUT == 2
                                    TO_PRINTER=OFF,$
                                  END_IF/
                                  IF/C4.INPUT == 3
                                    TO_PRINTER=ON,$
                                  END_IF/
                                    TO_PRINTER=OFF,$
                      AL
                      That works like a charm. Thanks eZalg!!! I owe you a beer.
                        I did like ezalg suggested, here is how I did it...
                        COMMENT/OPER,NO,FULL SCREEN=NO,AUTO-CONTINUE=NO,            REVIEW THE REPORT AND THEN CLICK OK TO CONTINUE.
                        PR1        =COMMENT/INPUT,NO,FULL SCREEN=NO,
                                                ENTER  1  FOR SAVE FILE ONLY
                                                ENTER  2  FOR PRINTER AND SAVE FILE
                                    IF/PR1.INPUT==1
                                      TO_FILE=ON,PROMPT,$
                                      TO_PRINTER=OFF,$
                                    END_IF/
                                    IF/PR1.INPUT==2
                                      TO_FILE=ON,PROMPT,$
                                      TO_PRINTER=ON,$
                                    END_IF/
                          Put a ticket in for the 2013 tech preview.
                          Seems you can't print several copies of the report via the (partprogram) print command.
